Seth wrote: ↑Mon Aug 14, 2023 10:00 am
I ran some numbers for you, Grant.
The calculated increase in maximum output based purely on:
- Xmax, 6.2mm to 8.5mm is 2.7dB
- Vd, 207.4cc to 321.12cc is 3.8dB
- Voltage Limit, 35V to 50V is 3.1dB
However, none of the simple calculations are really helpful without an accurately modeled or measured 2.83V response plot for the cab with each driver. One thing that sticks out between the two drivers is the DC resistance. In no way is it any sort of fact, but in my casual observation I've noticed that drivers with lower Re tend to have higher sensitivity in the plots I've compared. BP102's Re is 5.59Ω and KL3010LF's Re is 7.03Ω, which leads me to suspect that the KL3010LF may result in less sensitivity that could potentially offset some of the gains. But again, without and accurately modeled or measured 2.83V response curve, it's purely supposition. I'm convinced my Hornresp models aren't accurate enough to be reliable in this comparison. I wish they were, I'd post comparative graphs for you.
If you choose to upgrade, it would be great if you were able and willing to take before and after measurements.
Thanks for your efforts Seth.
I did ask Bill because he should have those plots, with the modelling software he uses.
As far as Re goes I reckon it misses out as a singular variable, because it doesn't account for AC reactance in the driver.
Just in case you didn't know, or for others, Re by AES standard should be equal to or greater than 80% of total impedance.
So one could almost argue that the Re of the BP102 means it should be classified as a 6 ohm nominal impedance driver.
It's probably called an 8 ohm driver because that was in keeping with it's right at the start design brief.
Re represents the lowest impedance in an impedance plot with a 0 Hz DC input, not near Fs.
It's unusual enough for any 2 drivers to have Fs at the same frequency, and similarly Re will be at a different impedance.
I think that skews comparative analysis.
My understanding is that sensitivity is of much less importance than design in horn enclosures, and more significant in direct radiators, hence the quote "it's the design, not the driver, that dictates response" which I often quote.
There's always exceptions, but point in case is Lab12 vs 3012lf. The lab 12 should win (and does, ever so slightly) in the same enclosure, because it has greater Xmax, greater Vd. It also has lower Re and sensitivity than the 3012lf. Obviously, the 3012lf has lower Xmax and Vd, but greater Re and sensitivity.
You might expect the Lab12 to beat the snot out of the 3012lf, but it doesn't. It has the same voltage displacement limit.
It always comes back to voltage displacement limits for me.
And IIRC, the top 2 most important criteria for those limits are Xmax and impedance in order of importance, with other variables following.
Perhaps the greatest thing about this proposed change isn't so much the increase in output, for me it's not having to run separate limited outputs for subs with different drivers. Everything will be able to be limited to 50V, meaning I can simplify my setup.
I don't know if my time frame will allow me to do measurements at this time...
