Simulating T48 in hornresp
Fastskiguy
Re: Simulating T48 in hornresp
I'm using some "cabinet grade" stuff now due to local availability. My demands are low so it's "fine" <-imagine a woman saying "fine" but I've also used some of the sweet 9 ply 1/2" stuff and there is no comparison. A little extra effort, a little extra $$, but like 1000% worth it.
Joe
Joe
Hello everyone!
I recently bought my first driver, that I will build my first T48 with. It is an RCF L15P400, the spec sheet you can find here: http://www.loudspeakerdatabase.com/RCF/L15P400.
The specs are in range for the T48 cabinet according to the plans, so I cannot wait to hear them! Will start building one, if that went well I will build three more
Thanks to everyone for helping me out in my journey of building my first cabs!!
It should work well. The Qes is on the low end of the range, so sensitivity from 35-40Hz is a few dB lower than the 3015LF, while sensitivity above 40Hz is a few dB higher. The suspension is a bit stiffer than the 3015LF, so it can use the same 40Hz high pass and 60v limiting.
Alright I see, is the few dB a significant change? Or is it still going to pack a good punch?Bill Fitzmaurice wrote: ↑Fri Jun 09, 2023 8:13 am so sensitivity from 35-40Hz is a few dB lower than the 3015LF, while sensitivity above 40Hz is a few dB higher.
It's not significant enough to hear it. As for 'punch', that doesn't come from below 40Hz, it comes from an octave above that.
Oh yeah, I know. But since you said 35-40Hz I thought there might have been a dip there, but I probably misunderstood. Thank you for clarification, Bill!Bill Fitzmaurice wrote: ↑Fri Jun 09, 2023 10:21 am As for 'punch', that doesn't come from below 40Hz, it comes from an octave above that.
Hello! I am going to build my first T48 in a few days. Waiting for the wood to get delivered, it will be baltic birch.
The Fs of my driver (RCF l15p400) is 36Hz, so if I am correct I won't need the chamber reducers right? I am planning to build two to start, but definitely want four as soon as possible (I will wait a bit, because of my budget). I am asking just to be sure, because it potentially saves a tiny bit of wood.
- Chris_Allen
Build one first so you can get into the groove and optimise your build process.
That is exactly what I am doing, sorry if it wasn't clear from my post. I am not planning to build two simultaneously.Chris_Allen wrote: ↑Wed Aug 02, 2023 6:32 am Build one first so you can get into the groove and optimise your build process.
P.S.: Could you please check out my other thread about the speaker cable, thanks in advance!
That is correct.
