horn brace placement J12L
May be a dumb question, but I was thinking that I might build a horn brace placement jig to get the braces exactly even... and I noticed that the plan says to place them "spaced evenly, roughly 4 1/2 inches apart." If they are spaced evenly, though, shouldn't they be closer to 4" apart? If I were to get things perfect for the first time ever 3 15/16" apart? Or do I put one in the center and the others at the top and bottom of the baffle opening? I am guessing it doesn't matter and I am being too literal minded here... Please type slowly as I don't read fast.
1 x DR250
1 x T39
1 x Omni 10
1 x DR250
1 x T39
1 x Omni 10
Re: horn brace placement J12L
What I found in Sketchup is that you are correct with the ~4" distance. I clicked on the "move" icon, clicked on the side braces (which were in a group) and then had good access to measure the horn brace distances.
Thanks, Tom
1 x DR250
1 x T39
1 x Omni 10
1 x DR250
1 x T39
1 x Omni 10
Thanks, Bill
1 x DR250
1 x T39
1 x Omni 10
1 x DR250
1 x T39
1 x Omni 10
