Hello.
I am setting out to build a pair of T60s with the single Lab15 (6 ohm) in each, as well as two Omnitop 12s with the Delta-12LFA (8ohm). I have a friend with a pair of amps for sale: A QSC PLX3402 (for the subs) and a Green Audio GAD1200 for the tops with 1200Watts. Wondering how I should set the amps, whether I should use these or purchase something new (maybe the crown xti series). I'm really at a loss here. He's selling the two amps for 600 canadian, which is a pretty good deal, even with no DSP or Active crossover capability (maybe a miniDSP to ride along).
Am Noob. Thanks for everything.
Need Amp Help
Re: Need Amp Help
ASD 1001S for the horn loaded tweeter sorry.
Re: Need Amp Help
The QSC3402 is great for subs. I can't find anything on the GAD1200....never heard of it and can't find anything when I search.SnakeMan wrote: ↑Tue Nov 01, 2022 10:53 am Hello.
Bottom line - get a driverack for DSP. You have to have good limiting, crossover, and EQ. Used PA, PA+, PX series are found easily and cheap. Rack it up with your amps and know that everything will always work.
Re: Need Amp Help
Is the GAD1200 a Galaxy Audio G-1200, perhaps?
Re: Need Amp Help
49 pounds!
I have 4 amps in my rack that don't total that much weight.
Re: Need Amp Help
Pfft it's a lightweight.
But if it is the amp, it would be fine for tops/mains...
