One Mic, One Line mixer?
Re: One Mic, One Line mixer?
#16 Post by Bruce Weldy »
J_Dunavin wrote: Fri Jun 24, 2022 12:54 pm
What do you guys think about this?
J_Dunavin
#17 Post by J_Dunavin »
#18 Post by Bruce Weldy »
J_Dunavin wrote: Fri Jun 24, 2022 3:58 pm dag nab it!
https://www.parts-express.com/Rolls-PM3 ... x-245-1114
I get that it's small, but for a few bucks and just a little bit more real estate, you can get a proper mixer that you can utilize for a lot of things.....and it has some EQ on it. The Rolls will probably do what you want, but it's a one-trick pony....that's really designed for in-ear monitoring. If it was $29, I'd say sure.....but, there just isn't the bang for the buck.
You could always just use a breakout cable from the source to two 1/4" TS and insert direct into the driverack. Just set the driverack input to -10 instead of +4. I'd hate doing this personally because you always have the chance of blasting the crap out of the system if the source was turned up and you didn't realize it.
Of course.....I like mixers. :mrgreen:
J_Dunavin
#19 Post by J_Dunavin »
good points.
Another reason why i was eyeing that USB MIX from ART. Since i am also doing those Zoom broadcasts for our church service, it would work for that as well.
howiez
#20 Post by howiez »
J_Dunavin, what do you use when you do your Youth Group dances, DJ off a PC? The reason I ask, with my current setup, I was leaning towards the small Yamaha recommended by Bruce. BUT, I came across a Focusrite Scarlett Red Solo. It had RCA line out, so I ran that to my Driverack with RCA-->XLR. It has USB audio, so i get my PC/DJ tunes into it. It has a front mounted XLR with level control for a mic. And it has one 1/8 TRS for instrument/line. You could probably run that with or without the PC like the other one you mentioned a few posts back. Focusrite link
Of course i lucked out my son had one laying around. And he says it was nowhere near the $100 for the current gen3. I see a few for $50 plus on FB marketplace. Also this, near you... M-audio link
J_Dunavin
#21 Post by J_Dunavin »
I currently have a very old Audio Kontrol 1 that I use with MIXXX, that happens to have mic and line inputs as well four balanced outputs, monitor capability and whatnot. I'll have to try again, but i remember this thing not working with just usb power and that i needed to have a laptop hooked up. I have looked at the Focusright stuff and would like to upgrade the interface for MIXXX, but if I do I would still like the four outputs option. The four outs gives me the option to assign two channels for headphone monitoring, something the Red Solo would not be able to so.
The M Audio piece looks nice and would work, so long as it passes audio without the need for a PC(just usb power).
I'll do some research on that guy.... thanks for the heads up, I love marketplace, it's like a 24 hour garage sale
howiez
#22 Post by howiez »
I think someone on here recommended the Audio Kontrol 1 for my setup, but I didn't find one yet.
Lucky you, haveing one already! Plug USB cable into the back of the Driverack. Mine (PA2) has USB for updating firmware I suppose, but you should be able to steal 5v USB power off it?
J_Dunavin
#23 Post by J_Dunavin »
Update, the Audio Kontrol 1 does not pass audio with usb power only. ( plugged into a powered USB hub) the usb light just blinks and there is no control.
Also… I have a Driverack PX, no usb 🤷🏻‍♂️
#24 Post by Seth »
Seems like this should work okay. Wouldn't be stereo, but looks like it would do what you want. There's an open box for $56 too.
Rolls 3 Ch. Mic Mixer/Combiner (MX310)
J_Dunavin
#25 Post by J_Dunavin »
Experimenting with what I have, this headphone amp works! I also tried a microphone into the input ( I know, wrong impedance) and it worked 😄
Is it right? No way! But it does get some audio through.
I promise I’m going to buy something proper 😄
