What solder do you use?
#1 Post by Bruce Weldy »
Several months back, I ran out of the solder I've been using for years. I bought a new spool and it's really been a PITA to work with. Doesn't flow well and it really grunges up my tip. I constantly tin the tip and wipe it, but it leaves bumps on the tip.
I wish I still had what I was using before....I thought this stuff would be close enough, but it ain't! Seems like it needs a whole lot more heat to melt too......
What is everyone using?
Re: What solder do you use?
#2 Post by Bill Fitzmaurice »
I bet what you got is lead free. You can get still get lead alloy solder, though it's expensive, like $25-$30 a pound. The good thing is a pound will last years, if not decades. I manage doing plumbing with lead free, which is a must there, but only with liquid acid flux and a lot of heat.
#3 Post by Bruce Weldy »
Bill Fitzmaurice wrote: Fri Jun 04, 2021 11:35 am I bet what you got is lead free. You can get still get lead alloy solder, though it's expensive, like $25-$30 a pound. The good thing is a pound will last years, if not decades. I manage doing plumbing with lead free, which is a must there, but only with liquid acid flux and a lot of heat.
I looked it up and it said is was 60/40. I wonder if the rosin isn't right? I paid about $25 for a pound spool from PE.
A friend of mine wondered if it was lead free also..... he uses Kester. May have to spring for another pound and throw this stuff away.
#4 Post by Seth »
This is the last stuff I've purchased and it seems to work as well as any other I've used. https://smile.amazon.com/gp/product/B076QG9N13
If the stuff you got isn't working well, I'd at least notify PE about the issue even if it may/may not be appropriate to request a return/refund at this point.
himhimself
#5 Post by himhimself »
Seth wrote: Fri Jun 04, 2021 12:29 pm If the stuff you got isn't working well, I'd at least notify PE about the issue even if it may/may not be appropriate to request a return/refund at this point.
+1 PE is so good with customer service, I'm certain they'd find a way to help you out.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#6 Post by Bruce Weldy »
himhimself wrote: Fri Jun 04, 2021 4:12 pm
Not worth the trouble over $25. And I've used it.
I ordered some Kester - it'll get here tomorrow and then I'll find out if it is indeed the solder that's the problem, because I am going to do some additions to a rack I built for a venue a while back.
himhimself
#7 Post by himhimself »
Just took a look in my tool box and I have a couple different sizes, all 60/40 Kester.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#8 Post by Seth »
Bruce Weldy wrote: Sat Jun 05, 2021 7:18 am Not worth the trouble over $25. And I've used it.
I was thinking more out of letting them know it's an inferior product, just so they're aware. Even an honest product review would potentially save the next guy some head scratching.
#9 Post by Bruce Weldy »
Seth wrote: Sat Jun 05, 2021 3:03 pm
Agreed.....but, I need to wait until I try something else to make sure it isn't something else in my setup.
NukePooch
#10 Post by NukePooch »
Also Kester '44' 60/40 here. Started using it years back, haven't used anything else since.
#11 Post by Bruce Weldy »
NukePooch wrote: Mon Jun 07, 2021 5:32 pm Also Kester '44' 60/40 here. Started using it years back, haven't used anything else since.
I just got a spool of it in yesterday. Waiting on a bunch of connectors to arrive on Thursday, then I'll take it out for a spin.
#12 Post by Radian »
+2 here. Good stuff!
#13 Post by Bruce Weldy »
Just want to report back. I've used the Kester for a couple of short soldering sessions and it is definitely better. Wish I had gotten the thinner stuff. This is a little to thick for my liking, but I'll get used to it.
The soldering iron tip is staying cleaner than with the other stuff and it flows much better.
#14 Post by Seth »
For reference, what size did you get that is thicker than you prefer. I never quite know what size to get myself. I have a few of those pencil size dispensers of the thin stuff for small delicate stuff, but prefer a little thicker for speaker wire size stuff. The last solder project I had was putting ring terminals on 1-0 AWG welding cable... the stuff I got for that project was waaaay too thin for the job. Seems like I had to use a couple feet of the stuff for each terminal.
jimbo7
#15 Post by jimbo7 »
Seth wrote: Mon Jun 14, 2021 7:16 pm For reference, what size did you get that is thicker than you prefer. I never quite know what size to get myself. I have a few of those pencil size dispensers of the thin stuff for small delicate stuff, but prefer a little thicker for speaker wire size stuff. The last solder project I had was putting ring terminals on 1-0 AWG welding cable... the stuff I got for that project was waaaay too thin for the job. Seems like I had to use a couple feet of the stuff for each terminal.
I've seen car audio guys fill terminals with solder then dunk the wire in. Even with the big thicker copper brazing-like sized solder.
The largest I've soldered with the pencil dispeners is 8ga strand wire. I just upped the heat and let it absorb till it couldn't take any more.
