Did you get authentic Neutrik connectors? Is the dish connector real Neutrik too? There's a lot of copy-cat crap out there.RYNO20 wrote: ↑Wed Feb 24, 2021 1:30 pmThey lock but not tightly like the straight onesBill Fitzmaurice wrote: ↑Tue Feb 23, 2021 10:07 pm I haven't used those, but seeing the latch release I would think they must lock.
Ryno — new from Illinois on the Mississippi
Re: Ryno — new from Illinois on the Mississippi
Says Neutrik and Liechtenstein .Bruce Weldy wrote: ↑Wed Feb 24, 2021 2:58 pmDid you get authentic Neutrik connectors? Is the dish connector real Neutrik too? There's a lot of copy-cat crap out there.RYNO20 wrote: ↑Wed Feb 24, 2021 1:30 pmThey lock but not tightly like the straight onesBill Fitzmaurice wrote: ↑Tue Feb 23, 2021 10:07 pm I haven't used those, but seeing the latch release I would think they must lock.
The tab on the straight ones is .200 wide and only has .003 clearance, the tab
9 that locates in lock) on 90 degree ones is .188 thick and has .015 clearance, wiggle room , wow.
If you see how they are built the long .090 dia. Pins make the contact on the male part is not much surface area, the spiral raised section on the receiver is not much area to contact, add up the tab lock being smaller and etc equals bad design. IMHO.
[/quote]
Interesting.....I've never used any of those....don't like the price and most everything I have has and inset plate - not sure if they would even fit.
Too bad it's not a good connector. I've yet to run across a Neutrik product that wasn't top-notch.
Interesting.....I've never used any of those....don't like the price and most everything I have has and inset plate - not sure if they would even fit.Bruce Weldy wrote: ↑Wed Feb 24, 2021 4:25 pmSays Neutrik and Liechtenstein .
[/quote] One of mine is reset because I was possibly going to lay it on its side and V=plate 2nd one. Others are vertically challenged, one for horns one for woofer, always keep color coded and simple. Never tried pass thru and 4 wire cable, permanent fixed.
The grey colored one is all plastic and tight , the others are metal locking bar and are loose even some of the straight ones I have are loose.
I’m going deep diving on this cause I’ve had problems with connections and always thought it was the wire. Also I’m using #1 pozidriv tool not a #1 Phillips.
Hope mixing nl2fc and nl4mpr matters?
That's not a problem at all. Years ago the old style NL2 panel mounts wouldn't take an NL4, but those days are long past. NL2FC is exactly the same as the NL4 - just 2 conductor instead of 4. Nowadays, all NL2 and NL4s play together. Just not NL8 - different animal.
Probably half my cables are NL4 and half NL2FC. All panel mounts are NL4. Never a problem.
Personally, I'd contact them. They seem like a company that cares about the quality of their product and just may not be aware of a manufacturing flaw.
https://www.neutrik.com/en/contact/contact-form
Not a bad idea, thanks I will.Seth wrote: ↑Wed Feb 24, 2021 8:21 pm Personally, I'd contact them. They seem like a company that cares about the quality of their product and just may not be aware of a manufacturing flaw.
Update Neutrik connection is perfect.
This morning I took all the receivers out and was going to test the loose problem. Turns out the 3 receivers were an off brand , wow human error again. I had stripped old speaker cabs for years keeping hardware etc. but used these 3 pieces because of size and not looking any further. I’ve only bought Neutriks for years knowing the cheap ones are just that.
So now all are replaced and functioning as the great product Neutrik is.
Going thru inventory today to put on EBay .
Great news! My faith is restored....RYNO20 wrote: ↑Thu Feb 25, 2021 11:43 am Update Neutrik connection is perfect.
Question??
I’ve been studying the SPL charts and need an education on how to use them.
I’ve only figured that to look at crossover points and Db levels and straighter lines .
Reason being that’s how I determined to build the T48 36 wide Lab 15 sub. There was a SPL chart comparing the T48 to my peavey SP 118 and I’m very satisfied in my choice.
Now I want to choose a top and I’m leaning towards DR280 because of the chart . Yes a few have advised it’s way too much , but what does that really mean ?
I’m using a DriveRack dbxpa2 with my iPad to tune and it really is a great way to experiment .
I’m using way too much amplifier watts compared to what the DRs will need and there aliment and curved horn are great.
All comments are welcome.
Look here:
https://billfitzmaurice.info/DR280.html
If you were to draw a pencil line across the SPL chart shown, roughly halfway between the peaks and troughs, it would be around 107.5dB 1W/1m
Add another cab (because you'd want right and left), add +6dB. So average SPL for the 2 cabs 1W/1m is 113.5dB
Now look here:
https://billfitzmaurice.info/T48.html
Do the same thing with the pencil line, between say 35Hz and 100Hz and your average SPL is around 103.5 dB 1W/1m.
Just on average SPL alone, the 2 x DR280's are twice as loud as the sub. You would need to build another 3 subs to keep up.
Or start messing with gains, which alters the crossover point, and/or EQ, which alters phase.
The DR200 has an average SPL of about 104dB 1W/1m for 1 cab. 2 would be plenty for your needs. Or 2 Otop12's...
Now look here:
Grant, don't forget about the Equal Loudness Curve
Glad you mentioned it Tom!
It should always be considered.
On the link you provided the equal loudness curve cites perceived SPL and
.when presented with pure steady tones
I've always struggled with equal loudness curves because of that, because music, live or recorded is anything but pure steady tones.
Since, by nature, SPL charts can only be generated across all the frequencies a driver or cab can reproduce, they have to be produced with, at a minimum, a cascade of multiple tones, in a sweep. They might be pure, but not steady.
I've never been quite sure if that then eliminates the equal loudness curves from the equation, but that's a philosophical discussion that might well clutter this thread.
What I can see though, based on what I said before, is , if we assume a crossover point of 100Hz between subs and mains, playing music, and average SPL for the two different cabs, with DR280's, 101Hz will be twice as loud as 99Hz if measured.
Once measured, that will alter perception.
Or, you might not even have to measure to come to the same conclusion...
Ok, digesting this at breakfast coffee the closer the average SPL is, the cab will be a better match.Grant Bunter wrote: ↑Fri Feb 26, 2021 3:33 amGlad you mentioned it Tom!
On the link you provided the equal loudness curve cites perceived SPL and.when presented with pure steady tones
Yes I read about the equal loudness curves wow.
How can I measure what I have? I like tools.
Thank you for your explanation it’s becoming clearer.
Alright looked them spl charts again (after one coffee) it seems that even Otop 12 if I put the 3012 in it will be too much.wow my head hurts.
DR200 with basic driver might be ok.
You have a driverack.....you can adjust there. OTops are an easy build and sound great.
