SethRocksYou wrote: ↑Sat Dec 12, 2020 6:19 pm
It looks like this is the Top Hat you have. You should have the depth available with about a half inch to spare, based on the SketchUp of my 2018 plans.
I'd consider using a forstner bit along with a drill guide like this. I think you can even screw it into place to keep it steady.
I'm afraid anything short of a really solid drill press won't be stable enough to keep the bit from grabbing and just tearing the brace up.
I hear ya. Easy enough to just use the router then. Hole pattern then clean it out to depth. Could even chisel out the portion the router wont reach if needed.
Everything has to be done (accessed) through that 1 1/2 hole. Chiseling would be pretty much impossible. I did find some long router bits - although with the router base obscuring the view, I'd be working blind in there.
Gonna' have to think about this one for a while....
Bill Fitzmaurice wrote: ↑Sat Dec 12, 2020 10:05 pm
I bet you could use a spade bit, just make sure it's really sharp, and that the tip is centered going into the brace.
My neighbor was over and we discussed that.....you think it would be better than a forstner bit? Seems like they'd both have the same problem catching on the edges.
Either way, it would probably be best to drill a small pilot hole all the way down to keep it centered all the way through.....
Thoughts that I had: predrill a pilot hole (necessary regardless of what is next), and then use a hole saw to remove the plug
: use a Forstner bit inside a sleeve to go through the brace
: use an oscillating saw to go through the brace, but it might be long enough
: use a chisel to finish removing the brace
: use a spade bit (after Bill made the suggestion)
This is definitely a challenge, but, I think that you have the skills to accomplish the task.
I'm starting to believe that Seth's solution is the best. That screw-in adapter looks to only go about an inch deep - a forstner bit could stay inside the top panel to keep it aligned only going that deep. Found a screw-in pole for $10 - different brand, but it's an M20 thread. I think I'd like that at 20 inches better than the adjustable one at 30-54". At 20 inches the top of the SLA will be a little over 6 feet tall. That's plenty of throw for this size system....trying to go higher and louder will bury the sub.
And if I need to get louder - I can always pack up my small rack with a driverack and a power amp and take along a T39.
SethRocksYou wrote: ↑Sun Dec 13, 2020 1:33 pm
Do you have casters in your T24? That pole could be awfully handy to use for wheeling it around without having to bend over.
Oh yeah....it's got wheels. I'm a big believer in wheels....
The only problem with the T24 is that it's really hard to lift. Just no good place to hang on to it. I've considered just putting a handle on the top back. Maybe even some cheap cup handles - one at the top of the mouth and one in back.
