3015LF ?
Chopthebass
3015LF ?
#1 Post by Chopthebass »
Hey,
I just got the Jack 15 plans from Bill and I see there is mention of the Eminence 3015 (although it says 350w and not 450w), but no mention of the 3015LF.
Just wondering if there will be any benefit installing a 3015LF? Although less sensitive it has nearly double xMax of 3015 and a lower frequency response.
Thanks
Re: 3015LF ?
#2 Post by Bruce Weldy »
Chopthebass wrote: Sun Aug 16, 2020 10:02 am Hey,
Thanks
You give up all the mid-range and highs with the LF. It's truly a sub diver. I built a Jack 15 with the 2515 paired with and old 75 watt peavey amp....plenty of low end and mids even without the tweeters.
Content in the 30-40hz range on bass guitar just comes out as mud anyway.....
