212 foam
Our easiest to build speaker lineup.
Jgriff
212 foam
#1 Post by Jgriff »
For a ported 212 with no tweeters to be used for bass is putting foam on the back and bottom interior sufficient or is there any benefit to doing a side as well or even foam the whole interior?
Thank you.
Re: 212 foam
#2 Post by Bill Fitzmaurice »
Damping may also be used to line the cab top, bottom and sides. It’s a chore to work around the braces, and the improvement in sound won’t be major, but if you want the best result possible do so.
Simplexx 12 plans.
Jgriff
Re: 212 foam
#3 Post by Jgriff »
Thank you. I saw that but was just curious if anyone else had an opinion or anything to add.
Re: 212 foam
#4 Post by Grant Bunter »
Well, the guy who created the design, then wrote the plans, quoted the plans.
My opinion would be to follow the plans!
BTW, welcome to the forum :)
