TITAN 48 in 89"
TITAN 48 in 89"
Hi, did someone build a Titan 48 in 89" but with only 1x15 ? i need plans but Bill send me the plans about T48 but in 62 cm not 89 with 1x15
Re: TITAN 48 in 89"
'The exterior width range with fifteens is 18 to 36 inches, using 17 to 35 inch wide panels.'
T48 plans, page 1.
T48 plans, page 1.
- Rune Bivrin
Re: TITAN 48 in 89"
Just to clarify: 18" (inches) is 45.7 cm. 36" is 91.4 cm. You've got to keep your eyes on the units.
If you bring up the SketchUp model, you can change the unit of measurement, but it does yield rather uneven numbers. I have found it easier to just get a steel ruler with inches on one side, and metric on the other.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
Re: TITAN 48 in 89"
If I had to build in mm/cm, I'd print the plans, go through them, convert every measurement off the bat, and hand write the conversion into the plans. It's not too dificult.
To convert fraction to decimal, divide the top number by the bottom number.
To convert inches to mm, just multiply by 25.4.
Example: 48 7/8"
7 divided by 8 = 0.875
48.875 inches x 25.4 = 1241.4mm
Would probably take less than 15 minutes to convert every dimension in the plans and be ready to read through them the recommended 2nd time. Might even double check my math the 2nd time through.
Example: 48 7/8"
Re: TITAN 48 in 89"
Or just type xxx inches into Google and it will respond with an inches to cm table. Just type in the inch measurement and it will give you the cm......without all that pesky math.
Re: TITAN 48 in 89"
+1 that's what i do
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
