Hi from Florida!
88h88
Re: Hi from Florida!
#16 Post by 88h88 »
If you're going Tuba 60 then you might as well use the Lab15 and do the cabs 27" wide for the most bang for your buck. The Delta 12LFs have about 1/3 the xmax of a Lab driver so aren't capable of pushing enough air so they're not suitable at all for this use.
Trent Swei wrote: Tue Mar 12, 2019 11:02 am Is there a reason though that the Tuba 60 requires the LAB12 drivers instead of the Delta-12LF drivers recommended for the Tuba 30s?
The T60 was specifically designed for the LAB drivers. The D12LF is the least expensive driver recommended for the T30, not the best. Phrases often used here are 'Buy once, cry once' and 'You only get one chance to do it right the first time'. Heed them. :cop:
Trent Swei
#18 Post by Trent Swei »
Bill Fitzmaurice wrote: Tue Mar 12, 2019 12:41 pm
Wise words Bill. I appreciate the help!
mj90210
#19 Post by mj90210 »
All great advice posted as usual. If you don’t exclusively listen to EDM genres that their bass is centered around 35 hz and under, my advice would be build 4 Titan 48’s and power them with an Inuke/NX amp. Most music doesn’t extend to under 35hz and people will be more impressed buy the overall loudness vs extension.
Thank You All for Your Time!!...Really!
2xDR300's
4xDual-30” Tuba 60’s
Simplex 21" Eminence NSW6021
1x20” THT
TLAH‘S
SLA Center-9 driver and Surrounds
SLA pros
TrT 10" Driver-10" Wide
Auto Tuba 10" Driver
