Omni Top 12 build from Germany
Re: Omni Top 12 build from Germany
I actually had no subs hooked up at all. I wanted to hear the Otops for what they were. Although, I am planning to test the rig at a huge aircraft hangar here soon and I'll use the JBL PRX 818 set for that. I know the Otops will easily out run them but it's what I have until I build the T48s.
OK, cool.Bigcox4002001 wrote: ↑Sun Dec 16, 2018 10:43 pm I actually had no subs hooked up at all. I wanted to hear the Otops for what they were. Although, I am planning to test the rig at a huge aircraft hangar here soon and I'll use the JBL PRX 818 set for that. I know the Otops will easily out run them but it's what I have until I build the T48s.
When you have everything built, you can play around with the slope, slope type, and HP point for the Otops, to arrive at what you think sounds best to you.
You can do that as well with the PRX's in the short term, or not...
Thanks, Grant. As soon as I have access to that hangar I'm going to try them out with the JBLs. I'm looking forward to it.
