Not just a touch either, usually an entire open palm.
It is a skill I guess I have developed over time.
I always put down a piece of newspaper to rest the caulk gun on. There's always some ooze-out. The gloves stay one until AFTER the paper is thrown away.
I always let off the pressure on the piston of the caulk gun.....still a little ooze, but not much.Bill Fitzmaurice wrote: ↑Mon Oct 15, 2018 3:42 pm I had that problem early on, until I learned how little you should be using, and that you must cap the tube immediately after laying down the bead.
