First build titan 48
Bikewrench
#1 Post by Bikewrench »
Just completed my first build, a 24" t48 with a 3015lf. I recruited a friend with more woodworking skills and nicer tools than my harbor freight saws. It turned out great, the biggest mistake I made was pushing the top (right side really) 4/6 brace in too far. It knocked panel 6 slightly out of square so we had a bit of squeezing and clamping to do when it came time to put the other side on. Still need to add castors and a handle and paint it. Had a show on Friday night so took it out for test. It out performed the grund audio 2x18 that I've been useing on less power. Was bridging the amp, qsc rmx850, for the 2x18 and just running single channel for the t48. We cut panels for a second cab that I'll put on the other channel. Can't wait to get it built. Next show is the end of September, hope to have it completed by then. What are you guys using to seal the access cover? I cut up a bicycle inner tube that seems to be working well.
Bikewrench
Re: First build titan 48
#2 Post by Bikewrench »
Bikewrench
#3 Post by Bikewrench »
Bikewrench
#4 Post by Bikewrench »
Oops looks like the pics are reversed order, you guys know what's going on.
#5 Post by Seth »
Congrats on the success. What was your build time?
Bikewrench
#6 Post by Bikewrench »
It took about a week. 5 evenings, about 3-4 hours each. We cut panels for the second cabinet at the same time. Hopefully the next one will go quicker.
#7 Post by Seth »
That doesn't sound like very long at all. I look forward to seeing the pair painted and v-plated... and hearing your review of the pair.
#8 Post by Grant Bunter »
Nice!
How wide is your cab?
James Champer
#9 Post by James Champer »
Bikewrench wrote: Sun Aug 19, 2018 1:26 pmWhat are you guys using to seal the access cover?
Speaker gasket tape
https://www.speakerhardware.com/speaker-gasket-tape.php
Bikewrench
#10 Post by Bikewrench »
24". Can't believe how light it is. Haven't weighed it, but it feels like a feather compared to the 2x18.
Bikewrench
#11 Post by Bikewrench »
Thanks James I'll have to hit him up. I still need to order speakon jacks for it too.
#12 Post by Grant Bunter »
Bikewrench wrote: Sun Aug 19, 2018 4:28 pm 24". Can't believe how light it is. Haven't weighed it, but it feels like a feather compared to the 2x18.
Ok.
You need to add more mouth braces then, there should be at least 2.
The 6-9" spacing specified for the rest of the panel braces also applies to the mouth braces.
One thing you absolutely do not want is panel flex. You can't see it, but it robs you of 3dB in output
commander_dan
#13 Post by commander_dan »
Hopefully you put 2 sets of braces in the cab also...
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
If there are two sets on the inside of panel 6 then a single brace on the outside of panel 6 is enough, especially as panel 10 is where you'll find the least amount of pressure that could cause vibration. If there are only single braces throughout I'd be concerned.
Bikewrench
#15 Post by Bikewrench »
Good catch, Grant, I guess that's why it says to read through the plans twice before starting. The good news is on the first set of braces I had just read about the braces being 6 to 9 inches apart, so there are two sets of braces throughout the inside of the cabinet. I guess by the time I got to this point, I was just excited to be done and got in a hurry. Bill, if you say it's enough,I'm not going to doubt you. However, I will be building at least one more of these. I am more of a function over fashion guy, but would like the cabinets to match. Would it be stupid to build my second one with just a single brace? Or should I just take the extra time to redo this one and do the next one with two braces? Or should I just not care if they match?
