Titan 48 & DR300 Build
Re: Titan 48 & DR300 Build
Guido, PL is not available in all countries, but doesn't stop people successfully building.... Just make sure it is an expanding/ foaming glue? Most are moisture cure, so litely dampen joins before applying said glue. To double up your safety, you could try a caulking type sealer, smear inside on your joins and bingo.
Others may add/ confirm/ or straight up disagree!
2 x Jack 112
2512, one with melded array
To do list:
XF 212
2 x Jack 112
To do list:
XF 212
the gue i use is structan from the rectavit brand. it's pulyurethane based glue.
so like the plans say use a polyurethane woodworking glue. doesn't have to be
PL or structan , any brand will do as long as it expands enough to fill the gaps.
other people can correct me if i'm wrong.
greetz ketoet
greetz ketoet
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
Have some friends in Miami buy some and mail it to you.Guido La Fond wrote:
And if i cannot get PL Premium???
Or try Leland at speakerhardware.comBill Fitzmaurice wrote:Have some friends in Miami buy some and mail it to you.Guido La Fond wrote:
Well the Guerilla is an expanding, so can it work or not???
No. It is not a construction adhesive. If it worked it would be in the plans.Guido La Fond wrote:Well the Guerilla is an expanding, so can it work or not???
Bill Fitzmaurice wrote:No. It is not a construction adhesive. If it worked it would be in the plans.Guido La Fond wrote:Well the Guerilla is an expanding, so can it work or not???
Fair enough, point taken
Any more progress?
I bought a bottle of Gorilla glue to see what it's all about. I repaired a wood chair with it, and I can't say I'm impressed; it was still wobbly and loose after using the chair for a day or so. I ended up taking it all apart, cleaned out all the Gorilla glue and re-glued everything with aliphatic resin glue.Guido La Fond wrote:Well the Guerilla is an expanding, so can it work or not???
I suppose the Gorilla could be used for kid's projects where strength isn't important.
Bottom line is, use the PL or equivalent. Anything else is setting yourself up for problems.
T48s
WH8s
SX212
T48s
WH8s
SX212
Gorilla Glue will bond and seal just fine. It does not have high strength with large gaps, like most OTS woodworking glues. So you want good tolerances while building which means good tools setup properly and someone who knows how to use them. I use Gorilla Glue on all kinds of woodworking and the wood comes apart long before the adhesive. It also expands very well and I've had zero problems on my 4T48's and 8 OT12. One WH 8 has been a slight problem but that's more build quality since the WH6 was my second build and I've upgraded drivers twice and learned a lot since then.
I stop in now and then. I've been too busy using all my gear.Tom Smit wrote:(It's good to see you back, gdougherty)
Is there an SPL chart for either or both of the 18Sound drivers?Grant Bunter wrote: ↑Thu Feb 28, 2013 11:36 pmFrom the T48 plans:Ryan A wrote:That's funny, the 18sound has less xmax than the 3015. How will it take 20 more volts? I think not. Is the 80v for use as a top, perhaps?Grant Bunter wrote: huh?
I don't understand, why buy the 18 sounds and then take 20V off their war volume?
I would have figured, with a rig as big as the OP is intending, that every last ounce of juice would count...
Ryan,
the 3015lf limit is 60V and the 18sound 80V, I think there's quite a bit more output in the 18sound based cabs...
"The 3015LF, 4015LF and Lab 15 limit is 60 volts. The limit of the 12NLW9300 is 70 volts, that of the 15NLW9300 80 volts."
Also, it's only been 5 years. Assuming this monster rig got finished, could the OP please treat us to some pics?
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
