TLAH Pro 4x8 plywood?
Re: TLAH Pro 4x8 plywood?
I recommended TLAH based on it being a permanent install, which gives you the option of hanging the mains up out of the way. Another option is SLA Pro, which is much shorter.
#17 Post by Bruce Weldy »
harquahalas wrote: Tue Feb 20, 2018 4:39 pm Understood Bruce. I thought the TLAH might do ok behind the mics. If I'm going front of stage, the TlAH will be more slender, but taller. I will for sure consider the Omni top or DR250. Would one sound better than the other do you think?
I believe that any of the designs discussed thus far will be good choices. Ultimately, your decision will need to based on the physical structure that you are going to be installing these in/on, your abilities in woodworking, and cost.
Maybe a picture of the venue would help.
harquahalas
#18 Post by harquahalas »
Will the SLA keep up Bill? Would the TLAH be better or would they be pretty close for my purposes? Thanks!
Bruce Weldy wrote: Wed Feb 21, 2018 12:25 am Maybe a picture of the venue would help.
+1.
harquahalas
#20 Post by harquahalas »
Unfortunately, I need to build the speakers before the venue is finished. Will be about a 30'x60' room. 12' to 14' ceilings with wood paneling on the walls.
Post a diagram. And advise whoever is building it that wood paneling looks good, sounds bad. Required reading:
http://realtraps.com/articles.htm
harquahalas
#22 Post by harquahalas »
I will read the article now. Ultimately want it to sound good and look good. I was planning on building wood diffusers and will most likely be doing the finishing of the walls myself. I obviously don't know what I'm doing.....but I am capable of building stuff :/
harquahalas
#23 Post by harquahalas »
Bill, Do you recommend buying realtraps? Or should I be building my own stuff to stay money conscious? I've built pine diffusers before which was my plan for this room. I do have a limited budget. I imagine some barn wood type panelling will be fine as long as I'm finishing the room with acoustic traps and diffusers. I will keep reading through these articles.
#24 Post by Bill Fitzmaurice »
I recommend building traps, they're a lot easier to make than speakers.
harquahalas
#25 Post by harquahalas »
That's great news! Any how to sites anyone could recommend?
#26 Post by Tom Smit »
Here's one to begin... http://realtraps.com/howto.htm
harquahalas
#27 Post by harquahalas »
Ha ha. That would be fantastic if the place that builds these to sell told me how to make them. I found some diy stuff easily on the web, just didn't know if some methods/materials are better than others.
#28 Post by Bill Fitzmaurice »
Make a box, fill it with fiberglass, cover the front with burlap or other open weave fabric. It doesn't get any easier.
#29 Post by Tom Smit »
harquahalas wrote: Sun Feb 25, 2018 11:36 am Ha ha. That would be fantastic if the place that builds these to sell told me how to make them. I found some diy stuff easily on the web, just didn't know if some methods/materials are better than others.
Oopsie. They used to have a DIY bass trap page of which I couldn't find at the moment.
What Bill said about building traps.
Space it out from the wall/corner to be more effective in the lower frequencies.
#30 Post by Grant Bunter »
The Otop series has perhaps a few dB less in output than the DR series. Either will sound great, and crystal clear.
The Otop series you will build way faster than the DR series.
So it's a slight trade, time to build vs output.
Otops also naturally stack easier than DR's if you end up building more than a pair...
