MA3600VZ double binding posts
Is this amp OK?
monekh
#1 Post by monekh »
Have just picked up one of these and initially confused by the two pairs of binding posts - mentioned in the manual, but not much explanation...
I'm assuming there is no difference between connecting e.g. one driver to each pair of binding posts on a channel, and connecting two drivers in parallel on just one pair of binding posts?
My instinct would be to just pick one pair per channel to run to breakout panel / speakon beyond as usual, but wanted to check I'm not missing something important or useful with the extra pair of posts...
cheers
Re: MA3600VZ double binding posts
#2 Post by Bruce Weldy »
That's correct
Why not just daisy chain from one speaker to the next with a jumper?
Also, if the amp is in a rack - build a rack panel for the back of the rack, then the speaker connections to the binding posts with always be in place and won't be taken on and off - this is much more reliable over the long term. And it makes for a much quicker setup and tear down.
monekh
#3 Post by monekh »
Thanks for confirming that Bruce.
(Yes sorry wasn't very clear - that's what I meant by breakout panel / speakons beyond, we have a panel in our rack and are daisy chaining - just wondered if there was any benefit to using the extra binding posts instead, but glad to just carry on as normal!)
#4 Post by Bruce Weldy »
monekh wrote:Thanks for confirming that Bruce.
Now that I look at it, you did say a breakout panel.....somehow my brain thought "breakout box".
