No, you probably won't. But, limiting is not optional, and don't bother with any sub-synth, either. Just make sure all your subs are the same polarity, that you wall or corner load them and use a V-plate, if you can. All this adds up to free SPL.Specsto wrote:Thx Bruce and DjPhatman,
I think I'll go with it and limit at 50v. However I do want to high pass at 40hz (the only reason I'm building 4). I want the drum and bass to rumble/beat people's chests. It sounds like I won't need to get near 50v anyway.
I think for the size difference, you really should build T48s, as wide as you can transport. Driver cost (KappaLite 3015LF) is around the same as the 3012LF. But, 4 T48s go down to 35Hz with ease, and 36" wide ones are bass MONSTERS!
