"I want it but I can't see the expense so I'll give it a try and build it myself" Theatre......
My old amp rack was getting a little worn out and I wanted something a bit more professional looking. I looked around at the commercial offerings and picked out some attributes from those that I liked.
After a couple months of off-and-on considerations, I decided to put pen to paper and hammer out a prototype.
My self-imposed limitations were:
Use one sheet of ply.
Have a separate caster-board.
Be 14 rack units high.
I started with one 4 x 8 sheet of 3/4 ply, nothing special.
I had an old relay rack to saw up for rack rails.
I had casters and handles.
I used Kindorf for the door slides. (I found it to be simpler to do guillotine doors instead of mucking about with hinges and slam latches.
The prototype worked out so well that I went ahead and started a second one.....
