Advice needed for Zumba studio
y2kindyz
Re: Advice needed for Zumba studio
#16 Post by y2kindyz »
Thank you drey,
What mic do you recommend? How can I high pass the tops without the drive rack? I am getting the crossover bill suggested. Will that be enough to keep the sub frequencies out?
#17 Post by Bruce Weldy »
y2kindyz wrote: How can I high pass the tops without the drive rack? I am getting the crossover bill suggested. Will that be enough to keep the sub frequencies out?
I don't recall seeing where Bill suggested a crossover.....? Which one?
Most crossovers have a high pass filter on them.
y2kindyz
#18 Post by y2kindyz »
My bad, that was on another post for a pair of Melhart speakers I am repairing. The Eminence PXB2:1K6 2-Way Speaker Crossover Board 1,600 Hz.
#19 Post by Bruce Weldy »
y2kindyz wrote:My bad, that was on another post for a pair of Melhart speakers I am repairing. The Eminence PXB2:1K6 2-Way Speaker Crossover Board 1,600 Hz.
That's a passive internal crossover between the woofer and horn.....no high pass there.
Some amps have a high pass option, but it is typically set at 30hz or 100hz.....neither of which is any good for running full range tops without subs.
Build some T-39s, buy a used driverack, a used mixer, and a used power amp. The budget will be low and you can make it work just fine.
y2kindyz
#20 Post by y2kindyz »
I hope to meet with her on Saturday and explain what she needs and the $$$ needed. I am thinking I may sell her my DBX PX and invest in a PA2, but guitar center shows some used PX's for $159. I would like to get at least $200 for mine, so we will see... So I may get her to go the guitar center route. we will see.
Thanks again for all your help guys, much appreciated,
Oscar
#21 Post by Bruce Weldy »
y2kindyz wrote: guitar center shows some used PX's for $159. I would like to get at least $200 for mine, so we will see... So I may get her to go the guitar center route. we will see.
Oscar
About $200 is right with the reference mic. $150-175 without the mic is what I'd pay for any of the PA/PX models (Those are the numbers that I have paid over the last couple of years).
Drey Chennells
#22 Post by Drey Chennells »
y2kindyz wrote:Thank you drey,
Bruce hit it all. On mic I was referring to the instructors headset and that can depend on the wireless system being used. I say upgrade because if youre getting a very cheap system the mic will be unsable. I've used these https://www.amazon.com/Shure-Wireless-F ... B00IVPFZ92 with good results but there are several good choices for this type of work.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
