Maslow CNC good enough? (or what CNC machine do you use)
infrasound
So maybe people on here have already posted or know of this but this machine is part of what inspired my reinterest in building speakers here: http://www.maslowcnc.com/
It made me want to ask, should that be fully capable of building every cabinet in the plans?
I wouldn't be getting it only to make BFM cabs, I have other projects in mind, it's just I know absolutely nothing about what a CNC machine's capabilities normally are or need to be or what to shop for other than considering them out of my price range forever. This is the first i've seen that is within reach. I don't know any reason it shouldnt work, unless the kerf width of a router cutting through things is too wide for certain plan cuts or something, it sounds like it's pretty precise.
What kind of CNC machines do you people need? Or/and what do you have to shop for to be able to make every cab in the plans so far? (and what abilities are even fancier, beyond what is needed, but might be worth having for other fancier compound whatever plans that other speaker designers might have... maybe making wooden tractix horns or whatever they are called/things you'd rarely want to try and do by hand ever)
Re: Maslow CNC good enough? (or what CNC machine do you use)
How have I never seen this?! The difficulty with CNC and BFM cabs is all the angles. You'll still need to tablesaw all of them, or change bits and have custom cutters. This though is cost effective enough that if you're doing multiple cabs it will make all the cutouts, braces etc stupid easy. Brilliant.
CoronaOperator
That looks like a game changer for the sheet goods CNC market. Very affordable and very little floor space too!
Like Lealand said, you still need to cut the angles and as you progress with the cab you would need to trim to fit as no glue ups are perfect, especially on something like a DR2x0.
needs plywood, 2x4's and some bricks? I have half the parts already! I'm in!
infrasound
It only just barely came out.LelandCrooks wrote:How have I never seen this?! The difficulty with CNC and BFM cabs is all the angles. You'll still need to tablesaw all of them, or change bits and have custom cutters. This though is cost effective enough that if you're doing multiple cabs it will make all the cutouts, braces etc stupid easy. Brilliant.
I'm hoping router bits are available at the angles needed or/and you simply set the router that way... i'm not a big expert woodworker, everything is vague since high school woodshop.
Would something like this save alot of work including on things like the DR cabs making it mostly screw'n'glue?
DR's are probably the biggest beneficiaries of cnc cutting. Nearly all the cuts are curved and straight edges.
They already make bits at an angle, but that won't achieve what you want. The panels in these designs almost always have 2 sides that are straight and two that are angled.....and the two angled sides are rarely the same degree of bevel or even the same orientation.infrasound wrote:
It would take way longer to keep changing bits than to just cut it on a table saw.
A friend a my has a 60 x 90 cm CNC router. Good for wedges and DR's! To small for subs... I've always wanted a CNC router that can cut full-sheets. It might not be extremely accurate, but a tablesaw isn't either. I ordered a place on the order list for 1$
Let's see what it brings. I can always say no...
Svartrose wrote: I might not be extremely accurate, but a tablesaw isn't either.
The first part of your sentence explains why you believe the second part.
A table saw performs perfectly as long as the person setting it up (extremely important) and the person using it knows what they are doing.
CNC machines are great, but for one-offs in the garage - I just don't see justifying the expense. However, this guy's little gadget might be pretty cool.
I meant It not I of course. This machine is 0.4mm accurate. It's not bad if you and your tablesaw are 0.4mm accurate, is it?Bruce Weldy wrote:Svartrose wrote: I might not be extremely accurate, but a tablesaw isn't either.![]()
The first part of your sentence explains why you believe the second part.![]()
infrasound
So is having the CNC that much of an improvement over just tablesaw cuts for all Bill's cabinets then, or is everything perfectly doable with a tablesaw and not extreme skill given a few jigs?Bruce Weldy wrote:They already make bits at an angle, but that won't achieve what you want. The panels in these designs almost always have 2 sides that are straight and two that are angled.....and the two angled sides are rarely the same degree of bevel or even the same orientation.infrasound wrote:
CNC would be great for outer panels with square edges or if you were doing a bunch of cabs of the same type where you could get all the panels cut to size, but the internal panels have to cut on a bevel.infrasound wrote: So is having the CNC that much of an improvement over just tablesaw cuts for all Bill's cabinets then, or is everything perfectly doable with a tablesaw and not extreme skill given a few jigs?
So, the CNC would be improvement in time savings for a bunch of cabs. But, a table saw can do EVERYTHING, whereas, a CNC cannot.
If you have both....use 'em. If you have to pick between the two, the table saw is the winner. What good would it be to have perfectly square panels from a CNC, if you then had to use a circular saw to cut the bevels?
