Setting limiters - Which mutlimeter?
Noclu
#1 Post by Noclu »
Hello everybody,
i worked thru the Setting limiter thread, and read what Bill wrote to the T60´s on the plans.
We run 2 T60 (15") on one Proline 3000 Channel in parrallel.
I took my cheapo multimeter and measured 50V (tested different frequencies from 50 - 200 without filtering - Had no chassis connected, just the multimeter)
After realizing my DCX2496 (probably) cant limit the Proline 3000 accordingly i built a small PAD Adapter to reduce the incoming Signal on the AMP.
Now i sent maximum Signal thru the DCX, measured around 50V on my multimeter and set the limiter that it won´t exceed 50V.
My question now is (as i´m no electronics expert, and not too good in english) Do i need to make the measurements with a true RMS multimeter?
I mean, the two T60´s are loud, but i got the feeling that i did something wrong.
As the AMP is rated 1300W at 4 Ohm. Without limiting i measured up to 130V (without PAD adapter) per channel with my multimeter.
Please correct me if i´m wrong, as i´m kinda new to the limiting stuff.
Blew 4 PD 1550 in our old scoops before and trying not to blow the two T60s
Thank you
Kind regards
Noclu
Re: Setting limiters - Which mutlimeter?
#2 Post by Bruce Weldy »
Noclu wrote: As the AMP is rated 1300W at 4 Ohm. Without limiting i measured up to 130V (without PAD adapter) per channel with my multimeter.
1300 watts at 4 ohms is 72 volts. Are you sure you didn't have the amplifier in bridge mode?
130 volts would produce over 4000 watts at 4 ohms.
What amp are you using?
Noclu
#3 Post by Noclu »
Oh, you´re totally right!
We use the T-Amp Proline 3000.
The amp shouldn´t be in Bridged mode, but accordingly my measures it must´ve been or my multimeter or the amp is defective!
I will take new measurements made sure the amp is not in bridged mode!
Edit :
But to get back to the multimeter - i checked the description - no info about true RMS or something in it. So i think it´s a Peak/Peak one?
What should i use as guideline for limiter setting?
#4 Post by Grant Bunter »
You don't need True RMS.
You are looking to measure AC volts. It seems what you have already is doing the job...
Noclu
#5 Post by Noclu »
Thank you!! :)
CoronaOperator
#6 Post by CoronaOperator »
Noclu wrote: But to get back to the multimeter - i checked the description - no info about true RMS or something in it. So i think it´s a Peak/Peak one?
The cheapo multimeters display a "calculated RMS" voltage which is the same as "true RMS" when measuring sine waves, up to about 3500 hz. Above 3500 hz they can be a few % points off. "True RMS" meters are only useful when the waveform is very irregular, has spikes,non-sinusoidal waves, etc.
Noclu
#7 Post by Noclu »
Thank you, too! :)
