What drivers will match or beat the cabs I listed in my original post?
PreSonus StudioLive 18sAI Subwoofers
PreSonus StudioLive 315AI Loudspeakers
PreSonus ULT 18 Subwoofers
PreSonus ULT 15 Loudspeakers
Yamaha CW218V Subwoofers
Yamaha C215V Loudspeakers
Yamaha DXS18 Subwoofers
Yamaha DSR115 Loudspeakers
Marching Band Sound Reinforcement
RustyGadget
Re: Marching Band Sound Reinforcement
RustyGadget wrote:What drivers will match or beat the cabs I listed in my original post?
I guess I wasn't clear. The ones I listed are the best options.So, $1500 should get you a pair of each if you build 'em yourself. That's with 3012LF in the subs and 2512s in the OTops...3012HOs will be a little more.
RustyGadget
I didn't get that from your post but that probably says more about me than about you. I appreciate your advice.
Any advice on amps. I'm not looking for bells and whistles. In fact the fewer buttons switches and knobs the better. This whole system will be left in the hands of high school kids to use for the marching band season.
I didn't make that clear at all....RustyGadget wrote:I didn't get that from your post but that probably says more about me than about you. I appreciate your advice.
As far as amps, there are several good options. Stick with lightweight options from Crown, Peavey, Behringer, or QSC.
Get a driverack and the RTA mic. Use it to set the system EQ outside. Save it to multiple locations on the unit so that when some numbnut starts screwing with it, you can put it back where it was.
I've helped with a few marching band competitions and have attended may more. One issue that I haven't seen mentioned here is that the band can not count on having AC power available at every performance venue. At least that is the case for dozen or so venues where my son's school competes. Nearly all schools in my area use a bank of batteries and a large AC inverter mounted in one of the their carts to power the equipment. The power piece has to be properly sized and factored into the cost. One advantage to using horn loaded cabinets is that their relative efficiency would allow for a smaller amps, smaller inverter and batteries.
Another factor is that the crew only has about 5 minutes to place and setup everything in the pit. There's no time of a complex setup or troubleshooting. Everything has to be plug and play. Passive speakers work best and wireless for anything that is not in the power cart.
1 x TAT - GTO804
1 x TAT - GTO804
- Charles Jenkinson
^^ I'm glad you mentioned this ^^
I didn't notice any cables in that video reference, so was wondering about power and signal. I also noticed they weren't school kids - that guy in the yellow had the best part - the camera seemed to know where to look and when, unless fixed in post production. Very impressive stuff, on choreography.
...overall then, what actual speakers you use are not a massive percentage of the cost and thought put into the system, but getting that bit right is a major bonus.
2xT30
2xT30
Good point on the power aspect. If you use battery/power inverter, might want to make sure to get one of the 'sine wave' converters...they're quite a bit more expensive, but they'll put out clean power, unlike the cheap 'modified sine wave' inverters.kkip wrote:I've helped with a few marching band competitions and have attended may more. One issue that I haven't seen mentioned here is that the band can not count on having AC power available at every performance venue. At least that is the case for dozen or so venues where my son's school competes. Nearly all schools in my area use a bank of batteries and a large AC inverter mounted in one of the their carts to power the equipment. The power piece has to be properly sized and factored into the cost. One advantage to using horn loaded cabinets is that their relative efficiency would allow for a smaller amps, smaller inverter and batteries.
The local bands I've seen tend to use one or two Honda or Yamaha 2K watt inverter generators on the cart.
RustyGadget
Sorry I haven't been back to this post but life has gotten hectic.
Thanks for all if the info so far. Yes, power is an issue but I'm not worried about that. We have a generator available and use that with our current setup. We have had too many issues with the power supplied by the venue. Usually just one extension cord. I do want to go with passive speakers, only one cable per caninet and no extra buttons or knobs to check before each performance. We do only have 2 minutes max for set up.
I've been trying to read as much as I can on here just to learn what questions to ask. Thank you all for your advice. I'll be back asking for more.
Rusty
Rusty
