Check your piezo's, Damp your cabs, Follow the plans!
Re: Check your piezo's, Damp your cabs, Follow the plans!
You can hear high order harmonics. Run a sweep from 2k to 15k. The harmonics will jump out of the horn. Above 12k they're usually quiet and harmless. Anything below 8k is grounds for dismissal.
I am about to start two J12Ls with full Piezo arrays. Is testing Piezos still recommended? I'm getting them from PE.
Yes.
Soooo... If I need 32 of them, how many should I get to allow for perfection- 10% or 20% or?
6-10 extra should be fine...nola50 wrote:Soooo... If I need 32 of them, how many should I get to allow for perfection- 10% or 20% or?
Apparently my PC does not generate enough power to drive the Piezos to any great volume. What is a good suggestion for amplifying the test sweeps from the Audion Sweep Gen free program?
I did it with the output from my iPhone.....you should have plenty with the PC.nola50 wrote:Apparently my PC does not generate enough power to drive the Piezos to any great volume. What is a good suggestion for amplifying the test sweeps from the Audion Sweep Gen free program?
Once the volume was cranked up, it all worked just fine.
Out of 42 I have 3 that are questionable after checking them all twice.
Re:
Haha!
If you'd have said (typed) nothing, it would have just sat there.
Still, there's valid info in the thread...
Re: Re:
I just meant JUST my post.... I posted in error, and deleted text with the edit function but could not delete the post. The info in the thread is definitely helpful! I just finished testing 50 piezos with the info here. Thanks to this thread I know that...Grant Bunter wrote: ↑Thu Aug 11, 2022 4:34 amHaha!
None had reversed polarity
All of them had capacitance between .167 and .120.
All worked.
Maybe I could contribute a rattle test. One that had capacitance of .162, worked and did not have reversed polarity was quieter than the others. It also had something rattling inside. On opening it, the paper cone was bent out of shape. It's my only bad one. Pays to get them from Speakerhardware.com or from Parts Express I guess.
1 x DR250
1 x T39
1 x Omni 10
1 x DR250
1 x T39
1 x Omni 10
himhimself
Re: Re:
For sure. This post helped me build my little test rig that made checking the piezos for my otop arrays easy. Found a fair number of bad ones that Parts Express forgave.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
