piezio sounding blown
halftank
#1 Post by halftank »
I have a Jacklight 12 with a flat array of 8 piezios and the recommended high and low pass filters. I have the piezio's switched so i can turn them off. Recently they have the vibration sound similar to a blown speaker. Do i have blown piezos, or something wrong with the high pass filter?? How do i trouble shoot this? I can build them, but lack the knowledge to source problems.
Wayne
Re: piezio sounding blown
#2 Post by Bruce Weldy »
Since you said vibration sound, more than likely you have a rattle. Check to make sure that the piezo array is tight and doesn't move - also any other things are can move......speaker wires, crossover, etc.
#3 Post by Tom Smit »
Sometimes there might be a loose piece behind the piezo cone.If you take the array out and shake it, there might be a rattle, in which case one would remove the back(s) to remove the "slug".
halftank
#4 Post by halftank »
All ready checked for rattles, loose items etc, even went as far to use isolation bushing on the array mounts, Noise is the distortion kind you get with a blown speaker!
W
#5 Post by Bill Fitzmaurice »
Try it with more than one source. If there's distortion in the signal chain piezos will reveal it.
halftank
#6 Post by halftank »
+1 Bill, you were correct, there was a bad source in the signal chain, turns out the right side of my amp has some slight distortion until it warms up.
thanks Man!
Wayne
#7 Post by Tom Smit »
:clap:
Glad you found it!
