Back from London and recovered.. for the most part. If anyone happened by The Steelyard last weekend for D-nox and Beckers, or by Parov stelar in Alexandra Palace, then I hope you enjoyed it as much as I did! As soon as I had free time I was back to work. Today I installed both of my panel 2's. I was hoping to see a load more of my build completed but I forgot about the hole for the driver in each of my panel 3, and my spacers themselves. They took the brunt of the work to get done today. And hopefully (I don't currently have an amp to test them with) they don't hit the rim of the holes. It doesn't seem like it could be possible with the stretch of the rubber but I could be wrong. Luckily I've secured a PKN XD2500, which I'm so so so eager to get my hands on, but that'll be a couple weeks away at the least.
I wish my photo's weren't too big to upload directly to the site but I'll have to make do. As you hopefully can see, there's a gasket that came with the LAB12s.. should I include that in my build or should I leave it off?
Tomorrow I'll hopefully get a good portion of my assembly done. All the rest of my pieces are cut to finished angles (asides from my braces, which since my cabs are 24" wide I'm fairly certain I'll need 2 of each) Bill says that the 3/5 brace is only used for the dual driver cabinets, but since my cabs are so wide is there a chance that I'd put one in too?
Thanks guys!
Pictures here
http://imgur.com/a/QRkAX
