Edge Roundover Techniques
What size router bit are you using to round over the edges of your cabs built with 1/2" material? What's your technique for something like the top or bottom front edge of a T39/48 where there is nothing for the roller guide to follow?
Re: Edge Roundover Techniques
3/8 looks best on 1/2 material.
always roundover from the top of the material whos edge you are rounding. doing it this way will prevent chipout from the router bit.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
- James Champer
If it wasn't clear about the mouths of T39's and 48's from what sine143 explained.ripNdeb wrote:What size router bit are you using to round over the edges of your cabs built with 1/2" material? What's your technique for something like the top or bottom front edge of a T39/48 where there is nothing for the roller guide to follow?
Same technique applies, set them flat on their back and route away. You just have to be real careful and steady as the router base has nothing to ride on but that edge. This goes for any open ends (think Otops/Jacks back panel area, etc.)
It's not tough if you pay attention and take it slow.
I agree with 3/8" bit for edges, but find using a 1/2" bit on the corners helps best fit with large corners one tends to use on subs...
Screw a guide board to the cab for the router base to follow.ripNdeb wrote:What's your technique for something like the top or bottom front edge of a T39/48 where there is nothing for the roller guide to follow?
- James Champer
I've never had to do that but, makes good sense!Bill Fitzmaurice wrote:Screw a guide board to the cab for the router base to follow.ripNdeb wrote:What's your technique for something like the top or bottom front edge of a T39/48 where there is nothing for the roller guide to follow?
3/8" is the standard for the plastic stacking corners too (although they'd work with 1/2", but wouldn't fully contact at the corner).
Or create an offset base for your router from 3/8" perspex - v. handy for other jobs too... any sort of profile work and with a few extra holes, good for a small circle jig also:Bill Fitzmaurice wrote:Screw a guide board to the cab for the router base to follow.
