Started cutting the sides, and marking internal panel positions.
Ripping the sheet in to 430mm strips. Very happy with the Festool tracksaw. That cheap Nilfisk vacuum has autostart which is handy.
It's good to have a place to sit down and study the plans just one or two more times, just to be sure. Max panel width doesn't leave a lot of room for errors if you plan to use only one sheet of 4x8 per AT. Building in the garage, so lot's of engine parts and other stuff competing for room.
Using a spare amp channel to break in the drivers.
Checking the fit of panel one. Crawling on the floor isn't very ergonomic. I've got a folding workbench on order but it hasn't arrived yet. Yes - that is a grease pit in the background, No I haven't fallen in it. Yet.
Working on the baffle, which took a lot longer than expected.
More progress tomorrow I hope. The system will be powered by a 5 channel class D amp from JL Audio, but I haven't decided on placement yet. Not really looking forward to routing power cables through the firewall and under all the carpets.
