http://billfitzmaurice.info/forum/viewt ... =5&t=23327
It will be mounted in the bed of my 84 Ford Ranger standard cab firing into my seat back through a "blow through"
The driver I am using are a pair of 1998 vintage Rockford Fosgate RFP2408's
http://www.rockfordfosgate.com/rftech/l ... LC_MAN.pdf
I spent a few hours reading over the plans then headed out to the garage.
It's official, the build has started.
The first side panel cut and marked out. Two of the external dimension cuts are rough because I will trim those flush after final assembly.
Please forgive my photo quality, I took them with a potato.
