SLA Pro Shorty (2x6) Build (Lots of Pictures)
What I am going to do is put up all the pictures, as they pretty much tell the build story and then I will go back and annotate a little bit.  Enjoy.
It sure doesn't look like much wood... These will have top hats and bottom hats so I can use them as one column and add a set of 4x6's in the future.
						Re: SLA Pro Shorty (2x6) Build (Lots of Pictures)
More pics...  Cutting out the handles.
More pics...  I added top (and bottom) hats, so I reused the speaker cut outs as added thickness inside the speaker both top and bottom.  This allowed me to recess the top (and bottom) hats and still have plenty of strength top & bottom.
As for the screw, don't use cheap ones. I had some small ones that were cheap, and they broke off on the speakon connectors. They were a pain in the rear to get out when the head broke off. Yes, I did it more than once
As for the hole in the speaker, be careful when screwing it into the cabinet. I started another thread to find out how to fix it. It was a very small hole and a quick fix with some craft glue.
