How bad did I screw up (down actually)?
Guitbusy
#1 Post by Guitbusy »
While screwing down the speaker, my screwdriver slipped and punctured a small hole in the edge of the speaker. I am pushing down on the edge so that the hole is view-able. Can I use a little super glue or other adhesive on the hole? Let me know your thoughts. Thanks. :wall: :cussing: :oops:
1 x Tuba 24 (24"x24"x24")
2 x Wedgehorn 6
2 x SLA Pro Shorty (2x6)
CoronaOperator
Re: How bad did I screw up (down actually)?
#2 Post by CoronaOperator »
That can be mended but you want the adhesive to be flexible. Superglue dries too hard for a surround. A "thin" layer of silicone works well as does a small piece of panty hose attached with contact cement with another layer or two of contact cement on top to make it airtight. If the speaker is visible then do the repair from the rear for aesthetics.
Guitbusy
#3 Post by Guitbusy »
It is very small, so I am thinking silicone alone might do it. Just use standard 100% silicone caulk, or a silicone adhesive?
2 x Wedgehorn 6
CoronaOperator
#4 Post by CoronaOperator »
Whatever you have on hand. Back in the day when flat head screws were the norm I bet you a good 1/3 of all drivers installed suffered the same fate, welcome to the speaker builders club :D .
#5 Post by Bill Fitzmaurice »
Use 'Aleen's Tacky Glue' with a bit of cheese cloth or silkscreen cloth.
http://www.michaels.com/aleenes-origina ... 14859.html
FrankORandle
#6 Post by FrankORandle »
After you have repaired your driver...
A good practice to develop when installing any driver is to use the fingers of your free hand as a wall between the shaft of the screwdriver and the cone. It is better to slip and stab your finger than to stab through the surround or cone.
2-TTLS w/Dayton RSS265HO-4 10" Reference HO Subwoofer
Guitbusy
#7 Post by Guitbusy »
FrankORandle wrote:After you have repaired your driver...
Great, thanks. The number of safety measures I implemented after I messed up was directly proportional to the amount of anger felt at realization... :wall: :slap:
2 x Wedgehorn 6
Rich4349
#8 Post by Rich4349 »
You could also take a 6-10" diameter lid from a coffee can or old Tupperware and cut a slit halfway to the center and then cut a 1/2" hole at the very center. Screw in through the hole and slide off the shield via the slit.
#9 Post by DJPhatman »
Guitbusy wrote:While screwing down the speaker, my screwdriver slipped and punctured a small hole in the edge of the speaker. I am pushing down on the edge so that the hole is view-able. Can I use a little super glue or other adhesive on the hole? Let me know your thoughts. Thanks. :wall: :cussing: :oops:
Best solution to prevent this from happening again is.... don't use Philips or straight slot screws. You can EASILY get hex head screws, cap head screws, torx drive screws, square drive screws, etc. your chances of slipping off are so low...
Charles Jenkinson
#10 Post by Charles Jenkinson »
Also, make sure the core of the screw/hole is drilled to the right diameter. If only the threads are biting, it shouldn't be an ordeal to drive it home.
2xT30
