Just posting this link as I was hunting up how to properly break in my new 15" that's going into my 36" cubed TubaHT
1) Download Audacity from their homepage
http://audacityteam.org/
Taken From
https://www.stormconsultancy.co.uk/blog ... -audacity/
Copy this code into a frequencysweep.ny file and place it in your Audacity plug-ins directory. You’ll need to restart audactity for it to register the new plug-in. Once you’re back in, click on ‘Generate’ on the menu bar and select ‘Frequency Sweep’ from the list of options. You will then be presented with a dialog containing sliders to play with the parameters of your sweep. If any of the limits are too restricitve for you, simply change the values in the plug-in file!
Code: Select all
;nyquist plug-in
;version 1
;type generate
;name "Frequency Sweep..."
;action "Producing frequency sweep..."
;info "by Adam Pope and Paul Schimmel"
;control startf "Start Frequency (Hz)" real "" 20 20 20000
;control endf "End Frequency (Hz)" real "" 20000 20 20000
;control duration "Duration (secs)" real "" 30 1 300
;control level "Level (dBFS)" real " " 0 -40 0
;control type "Sweep scale [1=Linear, 2=Exponential]" int "" 2 1 2
(if (= type 2)
(scale-db level (fmosc 0 (pwev startf duration endf))) (scale-db level (fmosc 0 (pwlv startf duration endf))) )
a perfect 10-100hz sweep that is 10 seconds long and looped backwards on itself for 20 seconds total can be gotten from here
https://www.dropbox.com/s/benilsysavy57 ... p.wav?dl=1
If I can help anyone else with a tone let me know
