Thanks for the compliment!LelandCrooks wrote:I too have built a jillion cabinets. Occasionally I use yellow glue for some styles, but none of Bill's. It can be done, no doubt. If I were doing it with a horn though, I'd caulk the joints. It's not so much about the strength (pl is stronger, I tested it) as it is the air. Even a pinhole will affect performance. Pl is as much about insurance against that as anything else.
You should run an impedance sweep when you're done if you're able.
Nice work btw.
I will definitely run an impedance sweep when the box is complete.
