Hello from NoVa
An Ex Parrot
Hello from NoVa
Hi--newbie here from Northern Virginia.
Question for the seasoned BFM pros: I want to build a small bass cab and no idea whether to do a Simplexx, Jack or Omni.
A few background criteria:
--Will be either a 112 or 115--not sure yet which size I'll use for the main driver.
--I have a full wood shop, so ease of building isn't really a reason to choose one from another.
--And I mostly play in my basement, so weight/transportability isn't really an issue.
--Neither is volume: I'm sure any of the three will be plenty loud for my purposes!
So, those factors aside, what are the important differences between the three models? I've read all the descriptions and am just not sure which way to go. Appreciate any thoughts!
Thanks,
AEP
Thanks,
AEP
David Raehn
Re: Hello from NoVa
Hey Ex Parrot,
Greetings from not-quite-northern VA (although my day job is in Manassas)!
Most of the bass players here seem to lean toward the Jack. I haven't heard them yet, but they seem to be the best bang for the buck-size-simplicity (keep in mind that this is a world-wide forum and there are quite a few of them out there).
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
Re: Hello from NoVa
Hi, and welcome to the forum!
Do you also play live?And I mostly play in my basement
An Ex Parrot
Re: Hello from NoVa
I used to, and would like to again at some point, but my "real" job and family responsibilities make that difficult.Tom Smit wrote:Hi, and welcome to the forum!
AEP
An Ex Parrot
Re: Hello from NoVa
Colonial Beach is a beautiful area--and quite a commute from Manassas! But I have a friend who lives just across the river from you and commutes daily into DC, so your commute probably isn't much worse than hers.draehn wrote:Hey Ex Parrot,
I have been leaning toward the Jack and appreciate your feedback.
AEP
Re: Hello from NoVa
Considering your criteria, and that you might play live, I would suggest a Jack112 w/melded array piezos and w/ a switch for half-on/off/full-on piezos. This would be a very versatile cab, and if you build a twin then you would have plenty of rig for the gig or you have a small powerful PA.
Re: Hello from NoVa
And I still like your username.
An Ex Parrot
Re: Hello from NoVa
Was it really almost a year ago I first posted?!! Still haven't built--still mulling options. Paralysis by analysis, as they say.
I decided I want to consolidate equipment in my basement: Rack mount power amp, with rackmounted preamps for guitar, bass and keyboard. Then there's the question of speakers for all this. A few thoughts:
1. Can I find one speaker build that will work for all this: guitar, bass and keyboard? My guess is that "one size fits all" approach is destined to sound like crap for one instrument or another.
2. Assuming separate speakers are needed, I'm thinking Jack for bass/keys, then a separate XF210 for guitar.
Thoughts?
Thanks,
AEP
Thoughts?
Thanks,
AEP
Re: Hello from NoVa
1. Yes the Jack would be the go to for this.....IF you are using a guitar modeler with amp simulation.An Ex Parrot wrote: 1. Can I find one speaker build that will work for all this: guitar, bass and keyboard? My guess is that "one size fits all" approach is destined to sound like crap for one instrument or another.
P
2. This is the better option for all concerned.....build a J15 for the bass and Keys and the XF210 for the guitar if you are using a standard amp.
An Ex Parrot
Re: Hello from NoVa
Fantastic. Thanks for the suggestions. One more question, this time regarding a power amp. Thinking of using this Behringer because it's cheap (why else would one choose Behringer?):
http://www.sweetwater.com/store/detail/NU1000
I realize that the 1000 watts is peak. In other literature, the RMS output is given as 110W RMS @ 8 ohms, 210W RMS @ 4 ohms, 380W RMS @ 2 ohms.
Given that I am a "basement player" and am not interested in destroying the foundation of my house or deafening the rest of my family, is an amp at this rating likely to be powerful enough to adequately drive a Jack 112?
Thanks,
AEP
Thanks,
AEP
Re: Hello from NoVa
While I'm not a Behringer fan, that amp will do more than enough for what you are describing.An Ex Parrot wrote:Fantastic. Thanks for the suggestions. One more question, this time regarding a power amp. Thinking of using this Behringer because it's cheap (why else would one choose Behringer?):
Thanks,
AEP
