http://www.thomann.de/gb/t-amp_ta2400.htm
So i managed to pick up one of these amps really cheaply (this is my first 'pro audio' amp), hooked it up to my omnitops and wowzies, awesome, pretty amazed by the power and the difference between my hifi amp lol, just wondering if this would be suitable to power a pair of omnitop12's on one channel and a pair of lab12 loaded tuba 30's (i've got the drivers, just haven't built the boxes up yet) on the other (mono)? or would i better off getting another amp to power the otops and using this to solely to power the subs (stereo).
some copy/pasted info from the website
the t.amp TA2400 MK-X power amplifier
2x 1200W/4 Ohms, 2x 650W/8 Ohms RMS, 19", input sensitivity 0,775V, slew rate 60V/µs, damping factor: 500:1/1kHz/8Ohm, short circuit protection, limiter, THD <0.05%/1kHz, 2U. In: jack+XLR, out: Speakon & binding post. Depth: 44cm. Weight: 19,7kg.
Thomann T.amp TA2400
OmniTop 12 x 2 (Straight Piezo Array)
Tuba 30 x 1 (Lab 12) (second one is on it's way)
Re: Thomann T.amp TA2400
If those are real numbers and not marketing hype - that will do nicely for a pair of tops and subs easily.Arben wrote:
2x 1200W/4 Ohms, .
- Chris_Allen
Thomann is a very well respected business in Europe, so the numbers probably aren't far off the mark.
Middelkevin
They have more than enough power, I've heard them before and the're what thomann says they are; very powerfull.
Price/quality is more then good!
Build:
2x Jack 15 3015/ASD1001
2x Titan 48 3015LF 36''
Building:
4x Wedgehorn 8
8x Otop J-array cabs
Building:
4x Wedgehorn 8
Yeah, very impressed with the build quality of the thing, recommended to anyone in europe who doesn't mind the weight
Middelkevin
And for those who do mind the weight, buy some Synq amps.
Build:
Building:
4x Wedgehorn 8
Building:
4x Wedgehorn 8
That Thomann amp is a workhorse amp. I've seen it used in many rigs. It's a well respected amp in the free party scene. Built like a tank and easy to repair.
