GTD Audio Antenna Connectors
y2kindyz
#1 Post by y2kindyz »
Hello all,
I have a GTD Audio G 788H with 2 Mics. I have broken 2 of the 4 antennas due to the location in my amp/mixer case. I would like to extend the antennas by running a wire from the unit to a location outside of the case. About 2 feet.
Does anyone know what the type of connection is used for the antennas?
It looks like a coax connection, but much smaller. I have searched on the net and have not been able to correctly identify them.
Thanks in advance,
Oscar
BrentEvans
Re: GTD Audio Antenna Connectors
#2 Post by BrentEvans »
Theyre TNC connectors. not BNC, TNC.
y2kindyz
#3 Post by y2kindyz »
Thank you Brent. TNC Got it
y2kindyz
#4 Post by y2kindyz »
Ok for those that may be interested. Here is a link to the cable that I found on Amazon.com to mount the antennas remotely.
**** EDIT: These did not work Bulkhead was different type (N-Type)
WLAN Coax Cable KSR195, N-Type female bulkhead O-ring to TNC male pigtail 50cm Ships from USA
http://www.amazon.com/gp/product/B00MLN ... 9VQQX5B1VJ
Hope this can help others
