Desperately seeking decent stage lighting
skyshinee0514
#1 Post by skyshinee0514 »
Can anybody please recommend a good quality and decent stage light for events at a reasonable
price?
I need a new moving head light. I don't like wash light , so something on a stand is what I aim
for.
It must be able to smooth scanning,horizontal scan 540 degrees, 260 degrees vertical scanning.
I originally bought two RGBW LED Beam Light Fixtures, but Some do not work right out of the box,
and others have issues after very little time or use.
Is there anything I can buy in let's say roughly $500 range? :) :D :o :?: :!:
Ryan Sober
Re: Desperately seeking decent stage lighting
#2 Post by Ryan Sober »
Chauvet Intimidator Spot 250.
J_Dunavin
#3 Post by J_Dunavin »
If you have DMX software you can write custom programs to it as well. Right?
CoronaOperator
#4 Post by CoronaOperator »
What are you using it for? Highlight DJ table, band (stage lighting), dancefloor only, etc?
For most lighting, wash lights are the base that you build on with things like moving heads and effects lighting added for movement and texture. One moving head isn't going to do much of anything. A pair can be ok for a dark dancefloor look or on either side of the DJ to draw attention but you'll still need some kind of wash light on the performer, preferably at least 2 as one light will cast shadows that need to be filled in from the other side. $500 isn't much for a moving head that has decent output, for that budget the Chinese heads on ebay are a good deal but cross your fingers that you won't need parts. IMHO anything under 60 w LED for a moving spot isn't bright enough to be worth the expense unless you're just doing small pub gigs.
If your're dead set on a moving head under $500 delivered, then these are a tremendous value for what you get, although without a controller, you'll only use a fraction of their capability on sound active. As always, haze really brings lights to life.
skyshinee0514
#5 Post by skyshinee0514 »
Hey guys thanks so much for all your answers. But here
I find two lights from this site:http://www.stagelasers.com/factory-prom ... goboswhite or http://www.stagelasers.com/newly-produc ... tical-zoom
I hope you have time and inclination to check the specs if it is decent and say what you think about it.I'd like to use them for many years.It looks very good and Anybody can give me some advice, many thanks.
