Managing cables
- jswingchun
Managing cables
What are you doing with cables to keep them separate when storing them? Right now I have a piece of velcro attached to one end with a zip tie so after I roll the cable I can tie it off with that velcro. It works, but I hate having the velco on the end as it is always snagging on things when pulling up cables after the show, and the cables stick together whenever they get the chance.
I think I read somewhere that some people use tie wraps off a dispenser like you would get for gardening and basically consider them a throwaway item at each show. Like this:
Does anyone have a better way of handling this?
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
David Raehn
Re: Managing cables
Here's one for the hard-core DIY crowd:
http://www.colomar.com/Shavano/cable_straps.html
Yeah, I know it's still velcro.....
Lot's of good info on the site though.....
I use these myself:
Velcro Reusable Self-Gripping Ties VEK90924
I call them 'cat tongues' and keep them on the end of the cable nearest the snake....
Hope this may help.
I use these myself:
Hope this may help.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
Re: Managing cables
Cables I've never found a problem, but a snake is a royal PITA. This is a good way to deal with those:
http://www.homedepot.com/p/Suncast-175- ... 5yc1vZbx7e
You can use them for power cords too, just plug in the cords to each other as an assistant does the reeling. You can do the same with XLR mic cables if you have enough of them to make it worthwhile.
David Raehn
Re: Managing cables
Those are great, Bill, but I hate the extra stress it puts on the cable ends. I hate soldering while at FOH.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
- jswingchun
Re: Managing cables
I don't want to spool them because I have various lengths and I group them by length in the tub to make it easy to grab the length I want. I'm thinking I may cut off the Velcro on the mic cables at least and try the tie wraps. If it works out I will do the same for power and speaker. I'm still open though if any one else wants to chime in.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
- Scott Brochu
Re: Managing cables
I to use the hose reel methodBill Fitzmaurice wrote:Cables I've never found a problem, but a snake is a royal PITA. This is a good way to deal with those:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: Managing cables
Speaker cables get velcro.
Mic cables get tied with a loose knot. Works great and no velcro to deal with. I even put a knot in my electrical cables.
Snake gets coiled into a plastic tote, using the over/under method. It comes out laying flat with no curls and loops. Another trick I use with it is to leave about 20 feet of the stage end of the snake out. Start coiling it into the box until all of the rest of the snake is in. Then coil in the 20 feet with the stage box on top. That way, you'll pull out the box portion to put on stage, but you only take out of the box what you need to get to FOH. The rest stays in the box. No need in coiling up 100 feet of snake if you only use 60.
- BrentEvans
Re: Managing cables
I buy roll velcro from Harbor Freight. Cut off only the length needed for the cable, cut a small slit in one end and use a small zip tie to fasten tightly to the male end of the Xlr or whichever end of the cable is at the rack or snake. The velcro wraps around itself while the cable is in use, never falls off, and holds great. For larger cables and snakes I use parachute cord, tied to the cable similarly with a zip tie. Always use 2 or 4 on larger cables and snakes.
gdougherty
Re: Managing cables
http://www.itapestore.com/velcroonewrap ... eties.aspx
They stick together occasionally, but I put them on the male end and generally disconnect one at a time as I pack up. I bought a spool of 900 for $150. Yes, you can buy other types for cheaper but these are the most durable I've found and they're also good on the adhesion. Home Depot sells a cheap roll of 75 for a few bucks, but the straps don't hold well if under stress.
For long power and snake cables I get the 24" velcro tie wraps from Lowes/HD and cut them down to the appropriate length. Medium sized power and speaker cabling gets 3/4"x12" straps from the first link.
- jswingchun
Re: Managing cables
This is what I have been doing. It works pretty well, but I just don't like the velcro sticking the cables together. I have also had the velcro splitting lately, not that it is a big deal to replace them.BrentEvans wrote:I buy roll velcro from Harbor Freight. Cut off only the length needed for the cable, cut a small slit in one end and use a small zip tie to fasten tightly to the male end of the Xlr or whichever end of the cable is at the rack or snake.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
gdougherty
Re: Managing cables
That's what cheap velcro does. Good velcro like I linked above, holds up much better. I also like that the velcro pieces loop around the cable without requiring a zip-tie as those tend to mess up the cable and your hands over time. In my case, looping the tie end back onto the cable wrapped portion in a large circle (not tight around the cable) tends to keep the velcro from sticking together (all fuzzy side out). It only takes an extra second or two when you loose the strap.jswingchun wrote:This is what I have been doing. It works pretty well, but I just don't like the velcro sticking the cables together. I have also had the velcro splitting lately, not that it is a big deal to replace them.BrentEvans wrote:I buy roll velcro from Harbor Freight. Cut off only the length needed for the cable, cut a small slit in one end and use a small zip tie to fasten tightly to the male end of the Xlr or whichever end of the cable is at the rack or snake.
Re: Managing cables
I have just a velcro tie on every cable and use the over/under method (thanks to you all here). I have a small bag for mics, mic and instrument cables and some power. Larger bin for all the big stuff.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
