Re-attaching the diffuser on a melded array
As I was finishing up the OT12, putting in the melded array, the diffuser I noticed was loose from the bottom 3 pairs of horns. Any suggestions on what is the better glue/method to reattach it? Model glue, super glue, PVC cement?
- SoundInMotionDJ
Re: Re-attaching the diffuser on a melded array
+1Tom Smit wrote:Hot glue.
There are "temperature grades" of hot glue. Get the "high temp" version. Do NOT get any on your skin...do NOT wipe any drips or "strings" with your hands....it is crafting napalm!
10 T39S + 10 DR200 + 1 T48
I'm familiar with hot glue (used all the time in the flower shop). I hadn't thought of that. But, I would like to keep it neater looking than a dab of glue. I'll have to practice my dabbing.
And THAT'S why you put grills on 'em.Dan56 wrote:I'm familiar with hot glue (used all the time in the flower shop). I hadn't thought of that. But, I would like to keep it neater looking than a dab of glue. I'll have to practice my dabbing.
love the 'spider webs' tooSoundInMotionDJ wrote:it is crafting napalm!Tom Smit wrote:Hot glue.
I use 2 part epoxy. Only a few days ago I had quite a bendy wooden diffuser due to warping
After applying the epoxy and clamping overnight, it's totally solid. I wasn't expecting it to hold as the bend was so great, but it's absolutely solid.
Just wanted to say, a thick version of super glue worked well.
I added my diffuser later after building my cabs.I cut and angled them according to the 3 degree splay in my cabs.I glued them in and added a screw at the top and bottom.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
I see what you did thereDan56 wrote:I'll have to practice my dabbing.
12" autotuba
Pair of O-Top 12s with Delta Pros
This is what I did. Screw means they ain't going ANYWHERE.djtrumptight wrote:I added my diffuser later after building my cabs.I cut and angled them according to the 3 degree splay in my cabs.I glued them in and added a screw at the top and bottom.
