Back to the grill cloth. One of the issues was I cut the front angle with a squared off top and bottom to fit the metal corner protecters (okay, didn't really follow the plans, did I?).
Next problem, couldn't find the right piping to match, but, its close enough. And since it has corner protectors and no Tolex, its an Egnater style, and not an exact match.
Since it was supposed to come close to matching, I did the Duratex a la Leland, with a faux leather look. Much better than the grainy rolled texture in this case.
End result: a MUCH larger sweet spot than a standard 2x cab, starting from right in front of the cab. With the Tweaker 88, and the cab on the floor, it was too loud, in a very good way. The high's come in at about 2' in front and go to a nice spot about 8' out. However, with the cab shooting at the knees, the eq and switches could be set so there was not enough of a difference there, and 8' out to where it would change just slightly enough to not matter. Slightly off center and the mids go along with the highs, BUT, its still there to where you can hear, and the sound doesn't completely disappear.
And, this is without breaking in the Eminence Legend V128's. Weight is right at 40# with the back closed.
Question: Open or closed?
Answer: Both. After playing closed and running the Tweaker through its paces (what a great amp!), the open back added a nice, open, airy "sound all over the place" dimension. Not as tight, but not in a bad way. Running into some jazzy stuff and closing it back up brought a tight, focused, smooth forward sound, in a very good way.
Okay, so this is more of a review than a build, so Mark can move it where it fits. Again, just sharing the results of what xf players already know - there's no need for a 412.
