2- 2x10 T30s
67baja
Re: 2- 2x10 T30s
#16 Post by 67baja »
Bruce Weldy wrote:Tape a piece of cardboard over those drivers! You're scaring the hell out of me. And a plastic bag taped over the backside too.
Then take the cardboard off right before putting on the second side. But, leave the plastic bags on so PL doesn't drip on 'em.
That a real big chance you are taking leaving 'em in like that.
Lol. I don't sweat the small stuff, Bruce!
I'm putting on panels 12 and 13 on cab 1 right now. I hope to get the side on tonight too. Cab 2 is still at panel 5
Rowan611
Re: 2- 2x10 T30s
#17 Post by Rowan611 »
Looks good. The only issue I have with Kregg Jigs is you have to use their screws (or so they say) - which aren't cheap. Are you using their screws? If not, that might be the cause of your 1/16 push out. I was thinking about buying one to build some furniture, but after I saw the prices on the screws I decided against it at the time. Now, I'm thinking about building a new kitchen table and desk for the computer, so I'm back to thinking a Kregg would be really advantageous. Do you think it's making your build go faster?
1299s L/C/R | Volt8s | Crown amps | 24" THT x 4| Minidsp 10x10 2x4HD | Panamax 5300PM | LG 65B6 | Oppo 203 | Crowsons | HoverBoss | Behringer NX amps
THT Build
67baja
Re: 2- 2x10 T30s
#18 Post by 67baja »
The screws aren't as expensive as I thought. A box of 1" screws are only like $3 or $4. I removed a lot of my screws after the Pl cured so I used less than a box between 2 cabs.
I think it sped up the build, but it make the build easier in a lot of ways.
Rowan611
Re: 2- 2x10 T30s
#19 Post by Rowan611 »
67baja wrote:The screws aren't as expensive as I thought. A box of 1" screws are only like $3 or $4. I removed a lot of my screws after the Pl cured so I used less than a box between 2 cabs.
Cool. How many screws in a box though?
THT Build
67baja
Re: 2- 2x10 T30s
#20 Post by 67baja »
100. I bought 3 or 4 boxes and have a lot left.
Rowan611
Re: 2- 2x10 T30s
#21 Post by Rowan611 »
Not bad. I thought they were more expensive when I was looking, maybe that was just the place I was looking.
THT Build
67baja
Re: 2- 2x10 T30s
#22 Post by 67baja »
Also, kreg screws are like recex screws. They have a drilling tip so you don't have to predrill.
Padde298
Re: 2- 2x10 T30s
#23 Post by Padde298 »
So... Can we get more of the build-pics? Maybe a glimpse of the finished project?
2 x TAT
Re: 2- 2x10 T30s
#24 Post by LelandCrooks »
Pocket screws will push you off your lines about 1/16. Check my videos for a pocket screw tutorialhttps://www.speakerhardware.com/how-tos/
