I mark the angle on the side as well, but that doesn't protect against an absent minded sawbladedjtrumptight wrote:^^^there goes a 23 x 52" piece of wood lol.I'm doing 2 of them and i havent wasted a piece of wood or made a bad cut on this build.Marking the width's works for me but i also mark the angle to be cut on the side so when i place the wood on the saw there is no doubt as to which way my angle should be.Faux127 wrote:I buy 4x8 sheets of BB and have the local hardware store cut them into 23x48 sheets for me. (unless I need sides, then 24x48). This means all of my panels are already the correct width. I just have a stack of 23x48's laying on my floor (maybe dewarping?)djtrumptight wrote:Looking good.The way i have learned to avoid wasting wood or cutting panels the wrong way is to draw dotted lines like this (---------)on the width side of the panels so i know not to cut that side.That cuts out ALOT of confusion and i havent cut a panel wrong since i have been doing this.
I just accidentally cut a baffle in a rhombus shape, rather than a trapezoid, then cut another 2in short for some reason (probably the beer), and also had to recut a mounting ring
Titan 48 x3
Re: Titan 48 x3
Re: Titan 48 x3
Been a while since I posted pics, been procrastinating a bunch considering I can't afford all the drivers yet! Here's where I'm at now:
Stack o' Backs
Stack o' Backs
Re: Titan 48 x3
Nice progress. Making me wanna get busy with the Table Saw. If you can do it with a circular saw I don't have an excuse.
Just a warning on drinking and power tools. Probably not recommended.
2-Jack 10
2-Wedgehorn 8
1-Auto Tuba
2-Wedgehorn 8
1-Auto Tuba
djtrumptight
Re: Titan 48 x3
I hope u took into consideration that u have to cut off a 1/2" on those back panels before you cut the hand holds.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: Titan 48 x3
Of coursedjtrumptight wrote:I hope u took into consideration that u have to cut off a 1/2" on those back panels before you cut the hand holds.
Re: Titan 48 x3
I made that mistake - recovery is that the handles on the bottom don't have room for the quarter-round inside.djtrumptight wrote:I hope u took into consideration that u have to cut off a 1/2" on those back panels before you cut the hand holds.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
djtrumptight
Re: Titan 48 x3
Yeah,i did that too,on my 2nd T48 that i rushed building trying to built it in time for a gig lol.billkatz wrote:I made that mistake - recovery is that the handles on the bottom don't have room for the quarter-round inside.djtrumptight wrote:I hope u took into consideration that u have to cut off a 1/2" on those back panels before you cut the hand holds.
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
