Banana Plug 4 ohm load
djtrumptight
If i plug one 8 ohm speaker into an amp via banana plug then plug another 8 ohm loaded speaker banana plug into the first banana plug would that produce a 4 ohm parallel load ?
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
CoronaOperator
Re: Banana Plug 4 ohm load
Yes
And if you add at least one more banana, it will be a bunch louder.
- Harley
That may appealto some.Bruce Weldy wrote:And if you add at least one more banana, it will be a bunch louder.
djtrumptight
Yeah but wouldnt that be a 2 ohm load ? I'm gonna put 2 DR 250's on 1 channel and 2 T-39's on the other channel for a 4 ohm load on both sides.Bruce Weldy wrote:And if you add at least one more banana, it will be a bunch louder.
Thanks fella's.
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
hmmmm......methinks I shoulda' put adjtrumptight wrote:Yeah but wouldnt that be a 2 ohm load ? I'm gonna put 2 DR 250's on 1 channel and 2 T-39's on the other channel for a 4 ohm load on both sides.Bruce Weldy wrote:And if you add at least one more banana, it will be a bunch louder.
Thanks fella's.
bananas.....bunch.....get it?
- Harley
Some people just can't see the puns to save their skin Bruce.Bruce Weldy wrote:bananas.....bunch.....get it?
Yep, not understanding banana puns can lead to a slippery slope.Harley wrote:Some people just can't see the puns to save their skin Bruce.Bruce Weldy wrote:bananas.....bunch.....get it?
- Harley
...and reveal some of those patchy brown bruises days later...Bruce Weldy wrote:Yep, not understanding banana puns can lead to a slippery slope.
Just for the record it would give you a 2.67 ohm load if you added a third 8 ohm speaker. 4 speakers would give you 2 ohms. Simple math is ohms (all speakers being the same) divided by number of speakers. So with 8 ohm cabinets 2 is 4, 3 is 2.67, 4 is 2, and 5 or more is a smoldering amplifier.
- SoundInMotionDJ
That joke has the shelf life of a banana.Bruce Weldy wrote:bananas.....bunch.....get it?
10 T39S + 10 DR200 + 1 T48
coolhandjjl
Time to play some Bananarama. Hottest chicks of '80's music other than Suzanna Hoffs (The Bangles).
John Luke
Pair of Omni 212's
Pair of Omni 212's
coolhandjjl wrote:Time to play some Bananarama. Hottest chicks of '80's music other than Suzanna Hoffs (The Bangles).
That's a trick question......
There was no music in the 80s.
Applause!Bruce Weldy wrote:And if you add at least one more banana, it will be a bunch louder.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
All right, time to quit monkeying around!
