best way to run 4 T60s
Is this amp OK?
snowphish
#1 Post by snowphish »
So we've almost completed the 3 extra T60s, so we'll have 4 in total, each loaded with a LAB 15.
Now we have the following amps:
2x Crown MT1200
http://www.crownaudio.com/media/pdf/legacy/102990.pdf
QSC MX1500a
http://www.usc.edu/student-affairs/bova ... df/mxa.pdf
Yorkville AP4040
http://yorkville.com/amplifiers_process ... ct/ap4040/
I'm thinking I should run one on each channel of the ap4040, and one on each MT1200 ?
Re: best way to run 4 T60s
#2 Post by Bruce Weldy »
snowphish wrote:So we've almost completed the 3 extra T60s, so we'll have 4 in total, each loaded with a LAB 15.
2x Crown MT1200
QSC MX1500a
Yorkville AP4040
Huge discrepancy of power between the yorkville and the Crown. Yorkie at 750watts/8ohm and the Crown at 310/8ohm. The crown will only deliver half the power. Same with the QSC.
Either put all 4 on the Yorkville or get matching amps.
snowphish
#3 Post by snowphish »
I was thinking of bridging the Crowns, I have seen the warning about voltage swing, but I don't really have much choice or budget at this point. I was also thinking of getting 2 more MT1200s eventually as to have one for each tuba, perhaps not such a good idea? even with proper limiting/tweaking?
#4 Post by Bill Fitzmaurice »
snowphish wrote:I was thinking of bridging the Crowns
:cop:
http://billfitzmaurice.info/forum/viewt ... =6&t=19292
I was also thinking of getting 2 more MT1200s eventually as to have one for each tuba, perhaps not such a good idea? :?
The Yorkville will run two per channel. It's all you need.
snowphish
#5 Post by snowphish »
Alrighty, thank you! This does make sense, although it won't leave much headroom, if its safer for our drivers than bridging then it's the way to go. We finally have a hard limiter (driverack PA2) so we'll set it right.
BrentEvans
#6 Post by BrentEvans »
snowphish wrote:Alrighty, thank you! This does make sense, although it won't leave much headroom, if its safer for our drivers than bridging then it's the way to go. We finally have a hard limiter (driverack PA2) so we'll set it right.
Headroom doesn't come from power, it comes from output capacity. The two are related, but not synonymous. The T60 has a defined output capacity set by its voltage limit. If you need more headroom (which means more output) then you need more T60s, not more power to each T60.
It is not safer for your drivers to have far more voltage available than is required. When you use a hard limiter, the limiter cuts off signal that is unsafe. As Bill said, the Yorkville has enough voltage swing for your cabs, so you don't need to get more by bridging, nor will you get more headroom by bridging, because you'll still have a hard voltage limit.
#7 Post by Bill Fitzmaurice »
With the sensitivity of T60s you don't need it.
snowphish
#8 Post by snowphish »
I understand this, but I did not realize that the ap4040 would be sufficient for 4 tubas; I mean supplying the LAB15s near their limit ~60v, without clipping. I will measure and set the limiter accordingly! THANK you very much for your help, this will be our first event with 4 T60s, outdoors in Montreal, cold and snowy but we'll have good shelter for everything; any issues for running power amps at -10/-20 Celsius? This is the 3rd year we're doing this event and the only problem we've had in the past was a Crown xls that blew a capacitor.
BrentEvans
#9 Post by BrentEvans »
snowphish wrote:have good shelter for everything; any issues for running power amps at -10/-20 Celsius? This is the 3rd year we're doing this event and the only problem we've had in the past was a Crown xls that blew a capacitor.
The only thing to watch out for is condensation. Generally, keeping electronics cool is good for them (unless you'r talking about LCD panels). The problem with being in sub-freezing temperatures is that when the amp heats up, moisture can condense out of the atmosphere and short things out. Is the shelter you're talking about a tent, or something like a trailer, which an be closed up and kept at least slightly above freezing?
doncolga
#10 Post by doncolga »
I run two T30's per side on one amp when I run all four and it does just fine. I have the voltage swing that I need with no trouble. Great to get all that from one little amp.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
escapemcp
#11 Post by escapemcp »
From the Yorkville specs:
Hum and Noise (un / Aweighted -dB): 0.971698113207547
:loler:
WTF? That's some hardcore accuracy! I would have guessed that at least 2/3 of those digits are the result of the noise floor of the measuring equipment, rather than the amp itself. Maybe it's because they are using A weighted measurements at the SAME TIME as unweighted :confused: :confused: :lol:
