Completely lost on HT amps with no, or low high pass.
Building a pair of THT's with the recommended drivers. Looking for a plate amp to drive them both but after reading through every amp post on this forum I see that they all seem to filter below a certain freq. I called PE and support said the SPA500 filter is set to 18hz, but their documentation states 30hz. On the other hand lots of folks on this board are using BASH 300 and 500, as well as the Dayton amps with success. The O Audio with variable high pass doesnt seem to be available any longer. Sooo, to use the low end freq the THT can produce, what's a suggestion for an amp to drive two of these these?
Re: Completely lost on HT amps with no, or low high pass.
the tht doesnt do anything below 20. the bash amps (with their filter at about 18hz) are perfect because they actually help protect against over excursion below horn cutoff.
I'd recomend a non plate amp anyways though. If using the dayton DVC (par wired for 4 ohm load) the Behringer Inuke 1000 dsp is a nice fit (at 300 w per channel at 4 ohms), and adustable dsp options/ limiters.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
I'll look into that. My Denon amp has DSP, could I get away with the nonDSP amp, or are there more settings there I'd be missing?
eh, if your denon has dsp (and can apply a couple bands of paremetric eq, and a hipass/lopass) then get a non dsp amp.
1x bastard XF208
1x bastard XF208
THT does not need high passing, as the excursion is at a maximum at 22Hz, and drops below that.sine143 wrote:the tht doesnt do anything below 20. the bash amps (with their filter at about 18hz) are perfect because they actually help protect against over excursion below horn cutoff.
Bill Fitzmaurice wrote:THT does not need high passing, as the excursion is at a maximum at 22Hz, and drops below that.sine143 wrote:the tht doesnt do anything below 20. the bash amps (with their filter at about 18hz) are perfect because they actually help protect against over excursion below horn cutoff.
i stand corrected!
1x bastard XF208
1x bastard XF208
That doesn't mean that a high pass has no value, as there's no point sending signal below the pass band to the speaker, nor is there any point having the amp producing it. But it doesn't specifically need it for excursion limiting.sine143 wrote:Bill Fitzmaurice wrote:THT does not need high passing, as the excursion is at a maximum at 22Hz, and drops below that.sine143 wrote:the tht doesnt do anything below 20. the bash amps (with their filter at about 18hz) are perfect because they actually help protect against over excursion below horn cutoff.
i stand corrected!
You might want to look at the Yung 500 watt plate amps. They are on sale at Parts Express now. I just picked one up - haven't used it yet though.
2x HL10c Table Tubas
9/12 TLAHs
9/12 TLAHs
Looks like I have a line on crown amps, and plan on getting the xls 1000. On one hand it is complete overkill for two THT's, but for the price I am roughly at the same as 2 plate amps.
