+1 on the DCX/Driverack as your next purchase. You'll get the system running much better with it, and you will also have the bonus that once limited (through the DCX/DRack) you cannot blow a driver
< It could pay for itself right there! You
need to be splitting that signal into mids/tops and bass and then amplifying each separately - are you already doing this via a HPF or LPF switch on those amps?? I
think that you really need to be high-passing your subs as well (you do with any of the bigger BFM subs) so that no frequency below ~40Hz (unsure on exact figure for T24 - it'll be in the "manual") reaches the sub.
If you opted for the Driverack, then you also get the added bonus of RTA ability, which can make even shitty speakers sound half decent! As DBX has just bought out the PA2, you may be able to pick up a new PA+ (the model it's replacing) for not too much dollar
Go with the DCX and you'd need a separate box to RTA. However, if you could borrow someone's RTA box, you could then RTA using that and then plug in the values into your EQ, which would work just as well
Hope this helps, if not, then feel free to ask for more info
