+1 to 88's response.M_mcgarry wrote:do i need an input and output on the cabs. im confused as to which is the correct leads xlr or speakon
ie everything up to and including the amp input should be done with XLR's whenever possible.
Amp outputs in modern amps should be speakon.
IF you have an old Jands amp or something similar, I understand your confusion, as they have XLR inputs and outputs.
Since you haven't answered Bruce's question, I'll ask again, what gear do you currently have?
What are you loading your cabs with driver wise?
Normally you would put in a plate with 2 speakon connectors wired in parallel, and another set of wires goes from one of the speakons to the driver in each cab. This means you can "daisy chain" or connect, 2 cabs per channel...
