T39 First ever cab build
				biggerrigger
Re: T39 First ever cab build
Can you believe that all that low end can come from a 12" driver. Try a stack of 4 of them.
4-25" Lab12 loaded T39's
2-DR250's Melded array
2-DR250's Flat array
I wanna built another one asap but I gotta built a pair of OT12's first.
Here is a 60hz test tone..... 118db at 21.2v from 7ft. way!! and it's in a bad spot in my room positioned in a less than desirable way!
Is it normal to feel afraid to turn it up to the 50v limit because it might break?! because that's how I felt!! It was hard to take the pic while plugging my ears!! I though I was gonna break too!! Haha!!
One last thing... I guess a QSC PLX1602 is under powering the sub? I was afraid to go higher also because the amp was almost maxed out (solid signal light just below clipping).
  and it's in a bad spot in my room positioned in a less than desirable way!Is it normal to feel afraid to turn it up to the 50v limit because it might break?! because that's how I felt!! It was hard to take the pic while plugging my ears!! I though I was gonna break too!! Haha!!
David Odell
Sound tech for Love Seed Mama Jump
Sound tech for dewey Beach and greater Philadelphia area.
Freelance Audio Tech
A1, A2, L2, V2, GT
A1, A2, L2, V2, GT
				biggerrigger
As long as all of your ducks are in a row let it rip. But be sure you have followed the guidelines in the plans for protection and construction. I routinely flog mine at full power and have nothing but smiles on faces when I do.
The charts do not do justice on the doubling of the cabs. It sounds much better that the charts would leave you to believe. Much smoother and full. So having said that get your other T39 built ASAP you will not be disappointed.
Congratulations on your build and stay with it.
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
+1biggerrigger wrote:Can you believe that all that low end can come from a 12" driver. Try a stack of 4 of them.
Donny Collins
Great looking box man. Very nice.daveode wrote:I just finished putting the last panel on. It all came out straight and square after adjusting 2 of the panel braces. Now I just have to wait for the caulk to dry to install the driver and do the leak testing. I can't wait!!
Donny Collins
				Titanium Hand
Good job
118 dB is plenty loud hey! All that from a single twelve enjoy your next builds and the finishing stages on this one.
