Need help with frequencies knobs on behringer cx3400
ondasticks
I have a 3 way setup 3 amps need to know about multiband limiter and delay how and why do I set those please I need a preset config to set mine properly
Re: Need help with frequencies knobs on behringer cx3400
Without knowing lots more information about the speakers and amplifiers and what you're trying to accomplish its hard to help.
If all else fails RTFM.
ondasticks
I have 2 18" peavy black widows in vega style box 2,5inch with a horn as drivers for mids and 8 piezo for high I want to have the crossovers frequency set correctly my set is indoors at the moment
Try googling "punctuation". It's an amazing grammatical device that makes it possible for others to have a clue about whatever it is you are trying to say.ondasticks wrote:I have 2 18" peavy black widows in vega style box 2,5inch with a horn as drivers for mids and 8 piezo for high I want to have the crossovers frequency set correctly my set is indoors at the moment
ondasticks
Ok let's try again I replaced my old DoD 834 crossover which by the way is very simplistic crossover. On it I had three knobs and a gain per side. Well it started acting up so I replaced it with a behring cx3400 crossover and everything I'm used to seeing except the delay knob and time threshold knob. I'm not familiar with it. Also at this point I'm not really proficient with frequencies at all so it is why I ask what are the frequencies for lows , mids, and highs. So if you don't know either please keep your negative comment 2yourself thank you.
Yes, I could help you.ondasticks wrote:Ok let's try again I replaced my old DoD 834 crossover which by the way is very simplistic crossover. On it I had three knobs and a gain per side. Well it started acting up so I replaced it with a behring cx3400 crossover and everything I'm used to seeing except the delay knob and time threshold knob. I'm not familiar with it. Also at this point I'm not really proficient with frequencies at all so it is why I ask what are the frequencies for lows , mids, and highs. So if you don't know either please keep your pie hole shut thank you.
But, I think I'll just keep my pie hole shut.
- BrentEvans
+1Bruce Weldy wrote: Yes, I could help you.
ondasticks
Never mind got my answer from a sound engineer not someone hanging in forums comparing sizes. Anyhow got a straight up answer from someone that knows what they're talking about.
Glad you got it handled. If nothing else, you've started using punctuation. So, I guess you did learn something here.ondasticks wrote:Never mind got my answer from a sound engineer
Gotta' go....time to measure.not someone hanging in forums comparing sizes.
Why the attitude?ondasticks wrote:Never mind got my answer from a sound engineer not someone hanging in forums comparing sizes. Anyhow got a straight up answer from someone that knows what they're talking about.
You have no idea what lots of people in this forum have credential wise.
And know what they're talking about.
Did you see your sound engineers ticket?
- Charles Jenkinson
Do you mean 'the ticket belonging to the sound engineer'...?
This is the funniest thread I've read in a long long time, anywhere! ...only eclipsed by Gregory East's description (in words) of the sounds a car audio system (playing modern music) was making, once, when he drove his cab by.
2xT30
2xT30
- BrentEvans
Hopefully you fed that person a bit more info than you fed us. If you didn't, and he or she still gave you an answer, maybe he or she needs to spend a little time on this forum "comparing sizes" because there are no cookie cutter answers to these questions.ondasticks wrote:Never mind got my answer from a sound engineer not someone hanging in forums comparing sizes. Anyhow got a straight up answer from someone that knows what they're talking about.
Glad you're working though!
Um, where should I set the knobs and faders on my mixer to get a killer mix, like I hear on the radio?
T48s
WH8s
SX212
T48s
WH8s
SX212
- BrentEvans
25 o clock, except for that one, which you have to set to blernsthirty.byacey wrote:Um, where should I set the knobs and faders on my mixer to get a killer mix, like I hear on the radio?
And don't forget to fap the foo with the florbocker.
Bullcrap.....that never works if you don't invert the phase reducer first.BrentEvans wrote: And don't forget to fap the foo with the florbocker.
